Help, Subs Compared To Cone Area
by no means am i a ground pounder but cone area is the way to go if u have the room.
for example: my friend and i have the same amount of power ~1000rms. he has a 12" RF T2 sub. i have 2 15" Kicker CVR's. mine is definately louder than his, even if my box is about half the size it should be.
plus we paid about the same
but your buddy has the upper hand on quality and probably sq
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
What are you smokin?
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
Nothing better than cone area. But Running 4 subs sometimes isent nearly as loud as just 2 12"s. Example haveing enough box space for each to maximize its potential is a big key factor. If you have enough box space for the multiple subs, let alone the power, electrical, amp power than absolutely!
what are you SMOKING
ive seen the cvrs even owned some 12s
and ive installed a t2 in a buddys car.
trust me the t2 has WAYYYYY better build quality. and much better sound quality.
yours will be louder soely due to cone area. nothing less nothing more .
for everyday bumpage a t2 is nothing to sneeze at.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
aight cool, i mean, i dont plan on actually being a groundpounder, but thats what i plan on going for when i get a new car, this EXT ranger doesnt have much room = ( figured i could try to toss 4 12s back there and get some decent sounds. i just want to be louder than my friend who wasted 3500 for 2 12w3's in the trunk of his 05' grand prix
$3500 for 2-12w3s?
Oooouuuch!
damn, $3500 for two $250 subs installed is crazy. Must have a big amp and super custom box
I would hope soo...@ least...
yours will be louder soely due to cone area. nothing less nothing more . for everyday bumpage a t2 is nothing to sneeze at.
I dunno if you can so that so matter-of-factley...
2 12's vs 2 12's.....cone area advantage? do you know the effective SD of each woofer?
Plus, It has a BIT to do with the install.
2 well installed CVR 12's (or just about any WELL installed vs poorly installed for that matter) will PWN some poorly installed stuff.
Assuming the T2's and CVRs are Both installed properly, the T2's should win, but on product alone there's no real way to tell...the install matters too much...what if the 2-T2 12's are in a VAN or excursion and the CVR 12's are in some tiny Hatch?
Look at the DISPLACEMENT of each woofer to choose subs...SD (cone area) X(times) XMAX (excursion) will give you the amount of air you will actually be moving, and then just make sure it's installed by someone who knows what's up.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
It's not just cone area. That's why 8 12's in prefab boxes recently got a whole 119dB at a soundoff here recently. Whereas 1 12" in a custom (pure spl though) box did 145s all day.
It's very important to keep the following (theoretical but very applicable) rule in mind:
Double the cone area, gain 3dB
Double the power, gain 3dB
So all things being equal, a single 12" with 1000w should be as loud as 2 12"s with 500w each.
Except in this case because you have a single $250 12" instead of 2 $125 12"s the speaker is more efficient and better made - thus it's possible for 1 12 to be louder AND sound better than 2 12's with the same power!
10.x volts fo' life!
the one guy has two 15s the other 1 12
if you had the 15s in the optimum box optimum wattage with optimum voltage. it would be louder than the one 12 due to cone area..
but if you had two 12s with everything perfect as mentioned above the two 12s would probably keep up because of more excursion but the 15s would still be slightly louder due to cone area..
also the t2 has the upper hand on overall quality. imho
also with the example of 8 12s im sure there is some cancelation goin on..
also doesnt a smaller box raise the overall freq response?
if this is the case couldnt it cause distortion. or higher frequencys giving a false sense of loudness?
feel free to crack the whip on me if im wrong or outta line.
Edited by cerwinvega
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
two twelves have more Sd than one 15
-Drew
the kid has 2 15s ..
the other kid has one 12...
that means the TWO 15s beat the ONE 12 due to more cone area
BUT if you had 2 t2s it would keep up with the two 15s because they have more xmax than the 15s
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
  • Who's Online   1 Member, 0 Anonymous, 1215 Guests (See full list)
