box tuning and db numbers HELP
I have Made a strong double floor/double baffle box with window bracing out of 3/4 MDF just a bit larger than spec . I am using white sewer pipe so I can run the sweep 90's and dual 4" precision port flares top and bottom for a single 12 in a test box and keep changing my tuning,
I have a cheapo db meter on the dash while running all my tests. Here's where I need you guys because I'm stumped. So why when I make the ports longer (tuned lower) would my 30 to 35hz range numbers drop? also why when I shorten the ports (tuned higher) would 56-62hz range numbers drop? I also cant figure out why I'm so peaky I have some notes like 40hz almost always falls on its face. Tuned at 31.5 and 32 it dies but tuned at 31 it doesn't? (I'm talking a whole 8db)  I also usually have a drop at 42Hz,43hz,and 52hz. I'm just lost as to why the numbers are so jumpy between tests. Why its a steady climb with drops and then back to a steady climb then drops etc. I start at 30hz and go to 62hz during these tests.
I honestly always thought the low range to a point would gain at lower tuning while sacrificing some higher notes and vice versa. Can someone tell me from experience in a test box with meter is this normal and how do you decide on a final tune? Is there an easy way to rid myself of the random peaks and drops? Every time I change the tune some numbers go up and some numbers go down but not consistently on either end as you would think. It seems random.  I love the 30-40 range
Thank you in advance for taking time to read and respond. This place is the best. If anyone can set me straight it will be here.
Most likely you are seeing peaks and nulls due to the environment the enclosure is in. You can try positioning the enclosure differently and see what changes can also use an eq to tame the peaks and valleys.
  • Who's Online   0 Members, 0 Anonymous, 1413 Guests (See full list)
