2 orion hcca 5000.1d spl amps
Have you done 'the big three'?  With a 10kw+ system, you'll need to do that and more.  You'll probably need to do 2 runs of 2/0 oxygen free cable to the lithium battery and then from there to a distribution block of some sort.  You'll need fusing for all of it.  A 10kw system ain't fukinn around and you want to do it right.  Your 2 ga welding wire won't be doing it right and may be dangerous.
Seriously, make a thread in the members build section so that others will know what you are trying to do .  There are definitely folks here who know how to put together badass heavy hitting systems and they will talk to you about it.
Orion XTR amplifiers
Skar subs
1) crazy8 is right
2) in order to hold 14+v on 2 5ks youre going to need more alt and a lot more of it
3) you going to need to up your wire as well.. especially with lithium as the current discharge is A LOT more than a normal battery.. i would suggest using a buss bur and coming off that lithium going to your amps.
good luck
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
But, your not gonna pull any where near max amperage. Those dyno runs are full rip, BURPs on tones, and  a REACTIVE load,..basically, worse case scenario
You really really wanna hold 14v, . Charge at 16, and run 14v cells.  Seems pointless to me, but, whatever peels your banana. Dropping some on voltage is not the end of the universe. It is a 12v board after all. I can see you already saying "but I want maximum power output" well, wiring at 1ohm nominal,  you wont see that anyway.
11 minutes ago, dimondntr2004 said:
big 3 done already. just need input to increase voltage. and have enuff battery for the system.
If you did it with that 2 ga wire it isn't done yet.  You'll need 1/0 minimum for that HO alt for power (fused at 350a) and ground, you'll need atleast as much total chassis-to-battery negative as you have in positive runs....so if you have 2x 2/0 ga (+) to the amps you'll need 2x 2/0 grounds from chassis to neg battery.
Skar subs
if your tryna hold high voltage try a buncha maxwell ultracapacitors
or add more alternators.
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
  • 11 months later...
  • Who's Online   2 Members, 0 Anonymous, 1794 Guests (See full list)
