Joshdashef Posted June 29, 2018 Report Posted June 29, 2018 Not sure if wiring is the right section for this but figured since its the fuse holder it fits At any rate, I switched from some sky high dual 1/0 terminal to SMD fuse holders and I love them. Only issue I have is with the one in the engine compartment. It is quite far from anything hot but still has decided to curve downward as shown in the picture Will this curve cause issues or potentially snap the fuse holder?? I've noticed the lugs seem to be looser than how I originally tightened them about a few weeks ago. Any help would be appreciated. The zip tie in the lower right corner of the fuse holder was not tightened down tight only to stop and side to side movement with a little slack. SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
meade916 Posted June 30, 2018 Report Posted June 30, 2018 the fuse holder is made of plastic. If you mount it on an uneven surface, hanging over the edge of that uneven surface, with the weight of 2 1/0 cables pulling it down while exposing it to a lot of heat, that could happen. That could happen to anything made of plastic. Email us at [email protected] we will give you a brand new one. The new ones are much better but you still need to find a solid surface to mount it to. thanks! All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
