them btls are laughing at that mojo
you only got 1 mojo?? the mojo 4000 only puts out around 2500 watts at 12 volts
2 mojos @ 14.4 would be perfect
x2
They are barely even moveing. They are laughing at that power and just asking for more power to get pumping!
yeah your btl's are just cross country runners taking a walk in the park
but im sure there already pretty loud but once you get another amp they'll be pounding your jeep apart
thank you. finally someone with a damn brain. that memphis amp is waaaaaay overrated.
my proof of this is, my local shop has a civic with a wall of 4 12's and they had that memphis in there and then they took it out and put a 3000 watt amp from us amps in there and it was a lot louder.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
The mojo is not over rated just rated at 16 volts not 12 or 14.4 it will do 4000 plus on 16 volts!
But ya its 12 volt output is lacking its still a soild clean lookin amp
im going to get a missing link when they finish them for Jeeps to help bring the voltage up they said it should be done sometime this month, ill make some more vids , it seems you guys are not happy yet
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Im guessing its ported? But couldnt tell from the vid...
the port is under the subs painted white
MLA module 15+volts
Team Bass Hz
