4th order 15 not hitting like its supposed to
At a glance it doesn't look like it would be due to any funky loading.
@Joe X helps a lot with box designs
Cabin gain might just be hurting you then. A trunk is a more controlled environment than a non sealed off blowthrough. I always err on the side of more port is better, regardless of port velocity numbers. I go with 50-60% of cone area as my target port area preference. 105" is 60% and 88" is 50%. You're not there with the current design, are you?
You need to get an accordion boot between bed and cab first(if that isn't done yet). Second, seal around box and inside of cabin, even if it's with foam pool noodles and duct tape.
11 hours ago, nickcamarata said:
drew up a quick sketch in sketchup image.thumb.png.108c7b1a2aa32e6069d1e907caaa24dc.png
This is not the correct way to do a blow thru enclosure. All of the enclosure’s strength is in the bed.
Just saying
  • Who's Online   0 Members, 0 Anonymous, 6509 Guests (See full list)
