2014 silverado alternator
kickass audio
Im looking to see if anyone has an alternator that is 250a or larger for a 5.3l v-8 GM engine that works on my 2014 silverado. I don't want to bypass the factory hall sensor so it must plug in with the factory harness.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
thanks everyone. I had a mechman in my previous truck (04 GMC Envoy) and still have the alternator but no longer have the truck. It sucks that GM made that damn engine with a different alternator case than the rest of their engines so it doesn't fit the silverado and I can't re-case it to make it fit.
What I wonder is since the truck has the hall effect sensor to change the load level of the alternator if that plays in my voltage bouncing around or if it's just from me putting such a load on the alternator. I noticed when I hooked up my old amp to the truck that the cluster backlights and lcd screen backlight would dim for a second and then brighten back up and then back down again. It does that even with just the windows being commanded to go up when they are already up so idk if it's just a delay in the truck sensing the load and boosting voltage and then dropping it back down or what it is.
  • Who's Online   0 Members, 0 Anonymous, 1405 Guests (See full list)
