Matt9ball Posted September 19, 2018 Report Posted September 19, 2018 Hi all. Hope someone can advise me. I have a 4 channel amp and a head unit with a pair of rca outs for front and a pair for rear. Also a sub out. Would like to connect 2 front speakers (6in 3 way) and 2 rear speakers (4in 3 way) as well as a 12in sub all to a 4 channel amp. I would assume it's best to bridge the channel 3 and 4 on the amp to the sub but not sure how to connect the hu to the amp.
bcbrassard Posted September 19, 2018 Report Posted September 19, 2018 Welcome.... Front speakers to ch 1 &2 of amp. Rear speakers to rear output high signal from HU. Sub bridged to ch 3 & 4. You really don't need rear speakers amplified, especially that small of speakers. This set will give you balance control, make your front stage sound the best and have a sub. A 5 channel amp would solve all your issues though. Good luck.
Matt9ball Posted September 19, 2018 Author Report Posted September 19, 2018 So i don't need to use the rear out or the sub out on the head unit? Also how do i select high only on the hu
Matt9ball Posted September 19, 2018 Author Report Posted September 19, 2018 ISo i don't need to use the rear out or the sub out on the head unit? Do i not use the rear out to the ch 3 and 4 of amp? Also how do i select high only on the hu
PaCiFiKbAllA Posted September 19, 2018 Report Posted September 19, 2018 The sub out is only if your running a seperate sub amp, in which case your not. Set the head unit to flat and use the HPF on the amp, at least that’s what I would do. As mentioned above, bridge the sub to channel 3 and 4. What deck and amp are u using? 1 x Fi Audio SP4 V2 12" D2 Fully Loaded 1 x Wolfram W-4500.1 2 x XS Power D5100's 250A Singer Alternator 2.67 Cubes @ 29hz
CstrokerV Posted September 19, 2018 Report Posted September 19, 2018 run the front rcas to channels 1&2 on the amp run the Sub outs to channel 3&4 dont use the rear outputs run the rears channels on the headunits output so just take out the old speakers and hook the new to the wires that are there or just use old speakers and dont buy new ones for the rear my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
Matt9ball Posted September 19, 2018 Author Report Posted September 19, 2018 6 hours ago, Matt9ball said: The deck is unfortunately only a Targa tdd 665 double din (all i could afford) . Speakers are all pioneer. Sub is 12in pioneer in a nice box. Amp is a Audio Bank pro NAB 4350.4. 1400w
Matt9ball Posted September 19, 2018 Author Report Posted September 19, 2018 29 minutes ago, CstrokerV said: run the front rcas to channels 1&2 on the amp run the Sub outs to channel 3&4 dont use the rear outputs run the rears channels on the headunits output so just take out the old speakers and hook the new to the wires that are there or just use old speakers and dont buy new ones for the rear Already have new rear 4in pioneers. Also there is only one sub out on the hu??
Matt9ball Posted September 19, 2018 Author Report Posted September 19, 2018 1 hour ago, PaCiFiKbAllA said: The sub out is only if your running a seperate sub amp, in which case your not. Set the head unit to flat and use the HPF on the amp, at least that’s what I would do. As mentioned above, bridge the sub to channel 3 and 4. What deck and amp are u using? Regards the bridging sub to 3 and 4, should i run the rear rcas from the hu to the amp to the inputs of channels 3 and 4?
