ky_coop Posted December 20, 2018 Report Share Posted December 20, 2018 I am looking at getting two of these tiny amps for my truck build i am starting soon. I need about 5-600 rms at 2 ohms for the sub amp and around 120-150 rms for my front speakers. i believe the 400x4 model is what i want for the speakers and the 500.1 is what i want for my subs. I know the 750x1 is rated alot closer to the specs i wanted, but the dyno video in youtube kind of turned me off on that( around 900w at 2 ohms). After watching that video i kind of thought that all the other amps in the line may be underrated like that one was. Has anyone dyno'd the 400x4 or the 500x1 model? If not do any of you still have the birth sheet from factory that may show what the amps truly put out? if neither of those put out what i am hoping for then I was thinking i may be able to run 2- 400x2's and use one for subs one for mids and highs. thanks Link to comment Share on other sites More sharing options...
bcbrassard Posted December 20, 2018 Report Share Posted December 20, 2018 Looks like the T500 put out close to 700 rms and the T750 closer to 1000 watts. $60 difference on amazon. Link to comment Share on other sites More sharing options...
ky_coop Posted December 20, 2018 Author Report Share Posted December 20, 2018 Is there a place I can see the dyno results on the 500? I haven't been able to find anything in my searching Link to comment Share on other sites More sharing options...
jmanjr82 Posted December 20, 2018 Report Share Posted December 20, 2018 are you concerned with the cost? With being such a small difference in power I would go for the more power option money permitting of course for various reasons. #1 have plenty of power on tap to keep your power clean, and #2 room for update and #3 cause why not? Link to comment Share on other sites More sharing options...
ky_coop Posted December 20, 2018 Author Report Share Posted December 20, 2018 Space is the main problem and money isn't a huge factor. Probably wont be upgrading anytime either subs will be 8" jl w3v3's. I'm just trying to not give way to much power to them like the 750x1 will Link to comment Share on other sites More sharing options...
jmanjr82 Posted December 20, 2018 Report Share Posted December 20, 2018 you control the power factor when you dial it in. Clean power is also the best option. If you get the 500 and max it out and leave more desired your at a deficit. If you get the 750 you can dial it in to around 500watts and have the option to go up to say 800watts. Is there really that much difference in size between the 2? Link to comment Share on other sites More sharing options...
ky_coop Posted December 20, 2018 Author Report Share Posted December 20, 2018 I dont believe there is much difference. Maybe a half inch longer if I'm not mistaken. What would u think for the speaker amp? 400.4 or 400.2 for the morel tempo ultra components. I think their spec is 140 rms. I haven't decided if I'm gonna run rears or not since I already have the speakers. Would also kind of like to be able to run active possibly sometime in the future Link to comment Share on other sites More sharing options...
jmanjr82 Posted December 20, 2018 Report Share Posted December 20, 2018 I would lean towards the 400.4 for more options. Its bridged power is more than enough for those morels, but if you did decide to go with rear fill you still have plenty of power. Link to comment Share on other sites More sharing options...
Kyblack76 Posted December 20, 2018 Report Share Posted December 20, 2018 http://www.b2audio.com/ma10004 High pass, low pass, and even band pass capability Just tossing it out there SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
ky_coop Posted December 20, 2018 Author Report Share Posted December 20, 2018 2 hours ago, Kyblack76 said: http://www.b2audio.com/ma10004 High pass, low pass, and even band pass capability Just tossing it out there I like the suggestion but I believe that will be a bit to long for the space I have available. Also, never heard of b2 audio Link to comment Share on other sites More sharing options...
