Kris4b11 Posted February 21, 2019 Report Posted February 21, 2019 Hey everyone, I have a 2014 Honda Accord with the "premium" system. I currently run a B2 Quattro for front mids and highs, B2 Mono for bass, and also a B2 MA1000.2 on pro audio drivers. I'm still using the factory touchscreen radio for my source and have a bypass/harness that grabs the signal before factory amp and converts high level into low level input that feed the amps directly. I am looking for a DSP that accepts RCA inputs but will also de-equalize and not fade out bass at higher volume. I really like how the new Zapco DSP Z8-IV-II looks and the program/app looks great to me. I was hoping someone could give me some feedback on this model and if it was capable of de-equalizing. I am also open to any other suggestions. Thank you in advance for your help. Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
Joshdashef Posted February 21, 2019 Report Posted February 21, 2019 I’ve never ran a dsp but the Rockford 3sixtys seem good just expensive. the audiocontrol dsps might be worth a look also. sorry I can’t say anything about the Zappos so just throwing ideas out SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
Kris4b11 Posted February 21, 2019 Author Report Posted February 21, 2019 4 minutes ago, Joshdashef said: I’ve never ran a dsp but the Rockford 3sixtys seem good just expensive. the audiocontrol dsps might be worth a look also. sorry I can’t say anything about the Zappos so just throwing ideas out Thank you for the reply I ran the 360.3 in my last build and had a few issues with it 1 being the 360.3 would freeze up on me resulting in me having to pull over turn the car off and starting back up, that being the only dsp I've ever used, I'm not sure if that's something that happens to any dsp or was just my luck. I am also considering the audio control dm 608 as another option. At this point I'm wondering if it might just be easier to stick a single din like a 80prs somewhere and call it a day lol. Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
bcbrassard Posted February 21, 2019 Report Posted February 21, 2019 I SUGGEST you buy it, Run it, Review It!!! Tons of DSP's out there. Not to sound stupid but what does de-equalizing mean? I googled it and didn't find a meaning for it. Equalize, yes. De-equalize, No.
Kris4b11 Posted February 21, 2019 Author Report Posted February 21, 2019 3 minutes ago, bcbrassard said: I SUGGEST you buy it, Run it, Review It!!! Tons of DSP's out there. Not to sound stupid but what does de-equalizing mean? I googled it and didn't find a meaning for it. Equalize, yes. De-equalize, No. Maybe it's not a "legit term" but I was referring to removing the factory EQing to get a "cleaner" signal. Also to remove the feature where the factory bass output signal drops as volume increases. Yes of course I could buy try it and hope and pray that it would do what i want. But I did not want to close my eyes and throw hundreds of dollars in the air that might end up out the window if you know what I mean lol. Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
reedal Posted February 21, 2019 Report Posted February 21, 2019 For what you want, go audiocontrol. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Kris4b11 Posted February 21, 2019 Author Report Posted February 21, 2019 Just now, reedal said: For what you want, go audiocontrol. Thank you I had a feeling that might be the way to go. I figured it wouldn't hurt to ask. Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
bcbrassard Posted February 21, 2019 Report Posted February 21, 2019 58 minutes ago, Kris4b11 said: Maybe it's not a "legit term" but I was referring to removing the factory EQing to get a "cleaner" signal. Also to remove the feature where the factory bass output signal drops as volume increases. Yes of course I could buy try it and hope and pray that it would do what i want. But I did not want to close my eyes and throw hundreds of dollars in the air that might end up out the window if you know what I mean lol. Gotcha, your looking for channel suming and acu bass. Audio control comes to mind as well. I used a LC7 from audio control on 2 builds with great results.
Joshdashef Posted February 21, 2019 Report Posted February 21, 2019 1 hour ago, Kris4b11 said: Thank you for the reply I ran the 360.3 in my last build and had a few issues with it 1 being the 360.3 would freeze up on me resulting in me having to pull over turn the car off and starting back up, that being the only dsp I've ever used, I'm not sure if that's something that happens to any dsp or was just my luck. I am also considering the audio control dm 608 as another option. At this point I'm wondering if it might just be easier to stick a single din like a 80prs somewhere and call it a day lol. Gotta say I love my 80 prs but I’m running active. I plan on going into a dsp eventually when I switch back to passive to add another set of speakers and judging from your experience I think I might go audiocontrol too 😂 SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
Kris4b11 Posted February 21, 2019 Author Report Posted February 21, 2019 11 hours ago, bcbrassard said: Gotcha, your looking for channel suming and acu bass. Audio control comes to mind as well. I used a LC7 from audio control on 2 builds with great results. Thank you! I think I am sold on Audio control now Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
