BassMunky Posted March 6, 2019 Report Posted March 6, 2019 Need help does it have a option to desulphate recondition mode or it will only detect it? Can you go directly into desulphate mode? Manually? Or the computer decides? Since my second battery resting at 12.3 2yr old Duracell agm group 31. What setting should I use on the ctek? Reg mode or try recondition mode? What the difference because doesn't the reg mode desulphate as the first step anyways? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted March 7, 2019 Author Report Posted March 7, 2019 Bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted March 7, 2019 Author Report Posted March 7, 2019 You gotta set the 2 settings? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted March 7, 2019 Author Report Posted March 7, 2019 Can I use the recondition mode or that only for dead batteries. It at 12.3 off? It 2 yrs old Duracell agm group 31 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Smoove Posted March 7, 2019 Report Posted March 7, 2019 Yes you can run recovery/desulfate mode before a battery is completely dead. If I remember correctly XS says run it every 3-6 months depending on use. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
BassMunky Posted March 7, 2019 Author Report Posted March 7, 2019 4 hours ago, Smoove said: Yes you can run recovery/desulfate mode before a battery is completely dead. If I remember correctly XS says run it every 3-6 months depending on use. What the diff between the 2 isn't it gonna be same ? The reg mode first step uses desulphate. So the recondition mode is different how? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
reedal Posted March 7, 2019 Report Posted March 7, 2019 What does the manual say. Reading the product manuals will answer most of the questions you ask SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
BassMunky Posted March 8, 2019 Author Report Posted March 8, 2019 1 hour ago, reedal said: What does the manual say. Reading the product manuals will answer most of the questions you ask Sorry seem like the same or the recon stay higher voltage. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
