3 way passive
Oldschoolaud
I'm building a 3 way front stage with a 7, 4 and 1 inch soft dome. I'll be running them off my old school Soundstream Class A and active isn't an easy option. Does anyone have any recommendations on good passives. The B2 3 way looked like a option or are there any others that have tweeter and mid attenuation.  Thanks for any suggestions.
How do you know your install requires a 3 way setup  ???
1 hour ago, ToNasty said:
Sometimes yes but a perfectly good 2 way passive can do the trick if done right
Are you feeling OK ?? Cause hell, I couldn’t have explained this any better.
I'm using Dayton Reference 4 ohm drivers. I was impressed by the um 12 flat response and output so I checked out other drivers and decided to try. The tweets are in sails and aimed dead center. They are amazing compared the the mb's that were in and have much better transition. I need to get 3 way cross before I'll fiberglass in new woofers.
  • Who's Online   1 Member, 0 Anonymous, 962 Guests (See full list)
