Help! Amp in protect Power and Ground Cable is heating up.
Bumping this subs like i stole them. I got a Cab2K at half ohm on 2 sundown x12. I got all sky high car audio 1/0 ofc from the front to my rear battery but from the rear battery to the amp the wire is 1/0 cca. Would this be the cause for my amp to be heating up or is it heating up from the abuse its getting? My electrical stays over 13volts I forgot to add that I have an excessive amperage 320 alternator.
Any tips and tricks welcomed not the first time ive had this issue.
YES cca is garbage and has a lot of resistance in it that turns into heat.
MEAD just did a video on this, also theres videos online that use a lazer gun to get temps, and same size wire same load and the CCA was over x3 the temp of OFC>
Also make sure your grounds are the same size as your power.
Pieced out the system little by little i thought i had ofc but i noticed ofc wasn't printed on the wire like the rest of my runs.
Thanx for the input much appreciated gonna order some ofc on Friday.
I can imagine some db gains from switching the wire.
  • Who's Online   0 Members, 0 Anonymous, 1372 Guests (See full list)
