Jmainbslappn Posted April 18, 2019 Report Posted April 18, 2019 Should I run 2 Taramps Bass 30ks each @.4 or 5 Taramps Md 8ks each @1ohm on 10 Resilient Sounds Platnium 18s which would be louder after impedance Rise?
DiBo Posted April 18, 2019 Report Posted April 18, 2019 2 Deaf Bonce Apocalypse AAK-20000.1D @ .4 @ 16v!! That'd be my choice. I don't trust taramps wired down. MD 8k's @1ohm wouldn't be enough I don't think.
Jmainbslappn Posted April 18, 2019 Author Report Posted April 18, 2019 Im on a budget can afford those unless I can get 2 for 3 grand
DiBo Posted April 18, 2019 Report Posted April 18, 2019 23 minutes ago, Jmainbslappn said: Im on a budget can afford those unless I can get 2 for 3 grand MD8k's then. That's a whole lot of gain matching. Hopefully minimal rise also. Should be loud regardless. Clamshell 4th order?
White Lightning Posted April 18, 2019 Report Posted April 18, 2019 You bought that much equipment with out a game plan ??? Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
SnowDrifter Posted April 18, 2019 Report Posted April 18, 2019 I assume you have some sort of external signal processor if you plan on using the 8ks? I have to ask... Are you serious? Or are you just mentally putting together a dream system? Any previous building experience? I ask because this sort of question really isn't typical of someone about to drop $25,000 plus on gear that takes more power than a typical neighborhood. Box built yet? Have you plotted your impedance rise? Contacted the manufacturer for more detailed specs/measurements/efficiency across impedance loads? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Jmainbslappn Posted April 18, 2019 Author Report Posted April 18, 2019 21 hours ago, White Lightning said: You bought that much equipment with out a game plan ??? My plan was the 5 8ks but it was brought to my attention that I could go with the 30ks and won't have to worry about doing so much gain matching plus with the 30k being wired low it would do better with impedance rise just wanted a little input Thats why i asked
DiBo Posted April 18, 2019 Report Posted April 18, 2019 16 minutes ago, Jmainbslappn said: My plan was the 5 8ks but it was brought to my attention that I could go with the 30ks and won't have to worry about doing so much gain matching plus with the 30k being wired low it would do better with impedance rise just wanted a little input Thats why i asked Taramps and wiring down are playing with fire. I don't care what someone else says. These amps aren't the most reliable... They get loud without question but reliability comes into play. The bass 30k's also need to be fed crazy amounts of juice. You'll be pulling around 6000amps of current with those so plan on at least 3 alternators ( 300 amps ea+) and around 400ah of quality lithium. $$$$$$$$$$$$$
Jmainbslappn Posted April 18, 2019 Author Report Posted April 18, 2019 19 hours ago, SnowDrifter said: I assume you have some sort of external signal processor if you plan on using the 8ks? I have to ask... Are you serious? Or are you just mentally putting together a dream system? Any previous building experience? I ask because this sort of question really isn't typical of someone about to drop $25,000 plus on gear that takes more power than a typical neighborhood. Box built yet? Have you plotted your impedance rise? Contacted the manufacturer for more detailed specs/measurements/efficiency across impedance loads? Signal processor of course yes im serious as you can see i already bought the subs and 300 ah worth of lithium, box not built yet Derek sindyla building my box,and plotting impedance rise yes that' s what im currently doing contacted manufacture yes I did,detailed specs yeah they haven't got back to me about the measurments yet Yeah its not typical but I got some years experience on installing basic to intermediate systems now I wanna to expand my knowledge some and take it to the next level
Jmainbslappn Posted April 18, 2019 Author Report Posted April 18, 2019 1 minute ago, DiBo said: Taramps and wiring down are playing with fire. I don't care what someone else says. These amps aren't the most reliable... They get loud without question but reliability comes into play. The bass 30k's also need to be fed crazy amounts of juice. You'll be pulling around 6000amps of current with those so plan on at least 3 alternators ( 300 amps ea+) and around 400ah of quality lithium. $$$$$$$$$$$$$ Right I got 4 ces 370s and 300 ah custom built cmax lithium if I have to add some banks then I will
