Zrafferty Posted April 24, 2019 Report Posted April 24, 2019 I have an Orion 2500d with a set of 4 power acoustik gothic gw3-10 1kw rms 2 of them are from a batch from release date and still work as day 1(ran mainly at .5 ohm). I bought another set so I could wire them for 1 ohm to reduce electrical load) The 2nd set before wiring all 4 I installed just the 2 new ones at 2 ohm to break them in worked fine. I then installed all 4 after 3 month one of the new subs smoked and got it warrantied. Another 2 months went by and then the sub I got warrantied got smoked as well. I bought another cause company wouldnt warranty the sub. I installed the one to replace warranty sub with 1 original 2nd set and then then the new one smoked again. Is there a reason only the freshest subs getting burnt and smoking and old ones are playing fairly? When last one blew it hasn't even been 2 months
Rich Schenk Posted April 24, 2019 Report Posted April 24, 2019 How do u have your gain set? All all the subs in individual chambers in the box or separate chambers? On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Skullz Posted April 24, 2019 Report Posted April 24, 2019 How exactly are they wired? Each sub wired in series and then in parallel? Or Each sub in parallel and wired in series? I always wire each sub in series and then parallel, so each sub sees power at the same time. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
BassMunky Posted April 24, 2019 Report Posted April 24, 2019 Check the wiring make sure no tinsels are touching. Disconnect everything double check Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Zrafferty Posted April 25, 2019 Author Report Posted April 25, 2019 I have had everything double and triple check after first one blew. My gain are set via dd1. And subs are in separate chambers It's a set of Orion double shot boxes For subs I have each box setup at 2 ohms via Subs parallels then series together. Then each box to it's own terminal on my amp(dual speaker thermal mono block amp
SnowDrifter Posted April 25, 2019 Report Posted April 25, 2019 Please verify resistance with a multi meter for each box. Then touch the leads together on your multimeter and post all 3 readings here ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Zrafferty Posted April 26, 2019 Author Report Posted April 26, 2019 I have verified them also used 9v pop test to confirm same phase
Zrafferty Posted April 26, 2019 Author Report Posted April 26, 2019 As if right now got 3ohm on 1 coil and 2.2 on the other(the sub that got smoked) I had it wired to 1.33ohm with all when first setup smoked on when I installed them which amp is rated for 2500@1ohm. 2nd time wired at 2.2ohm with only 2 subs hooked up (2nd batch with new warranty) amp rated for 1700@ohm Running stock electrical with big 3 upgrade using 0 guage. 2nd battery Optima yellow top gp78
Zrafferty Posted May 1, 2019 Author Report Posted May 1, 2019 Last one it did get louder then smoked seconds after like it was directly after breaking in period.
