MasterP Posted May 1, 2019 Report Share Posted May 1, 2019 I have 4 12s in a custom built box and have two amps I have both amps set the same way and all why do 2 of my 12s hit harder than the other 2 Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 1, 2019 Report Share Posted May 1, 2019 Could you provide info on how you're wired, how gains are set, and what you've checked so far? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
kookz Posted May 1, 2019 Report Share Posted May 1, 2019 Your box could have loading issues , one of the pairs are wired incorrectly or it could be an amp gain problem Walled Police Interceptor Four 15s 160s Link to comment Share on other sites More sharing options...
MasterP Posted May 1, 2019 Author Report Share Posted May 1, 2019 I got 2 Rockford fosgate 1200.1d the 4 12s are dual 4ohm sub both set are wired down to 1 ohm and how the box made the port is on the side at the bottom Link to comment Share on other sites More sharing options...
MasterP Posted May 1, 2019 Author Report Share Posted May 1, 2019 But I dont think it the amp I bought both of them brand new Link to comment Share on other sites More sharing options...
MasterP Posted May 1, 2019 Author Report Share Posted May 1, 2019 Could the rca do it too? Link to comment Share on other sites More sharing options...
kookz Posted May 1, 2019 Report Share Posted May 1, 2019 RCAs can go bad are you running the RCA pass thru one amp into the other or splitting before. Process of elimination maybe try one amp at a time then switch which pairs of speakers are connected to what amp.Will determine if its a RCA signal issue, amp issue or wiring. Walled Police Interceptor Four 15s 160s Link to comment Share on other sites More sharing options...
MasterP Posted May 1, 2019 Author Report Share Posted May 1, 2019 Ok let me go try it Link to comment Share on other sites More sharing options...
Joshdashef Posted May 1, 2019 Report Share Posted May 1, 2019 How did you gain match ? That’s probably the issue SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 1, 2019 Report Share Posted May 1, 2019 Get a multi meter and start checking and double checking. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
