I have a tuning calculator, i think exposport made it, In his calc the vent is always calculated inside the box, i want to know how do i edit it to make the vent external?
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
I edited this calculator to what i think should be right to give you tunning freq of internal and external vents.
again this is exposports calculator, i did not make it i thank him much for making it, i just made a small addition to it.
Can anyone please see if this is correct. Thanks.
small error... give me a sec to fix
edit: link removed
Edited by Clif
In Dash
Rear Flip Down
ok, here it is. again can someone maby check this. Im pretty sure its right, just want someones non tired eyes to look at it.
http://www.mediafire.com/?dayyngbgmnb
In Dash
Rear Flip Down
i did not make that one, tho thanks for the credit! ;) after i learn some programming, i will be making a GUI type calculator tho. should be fairly easy to use
lemme check this one real quick
thats the calc i made...and are u doing an external slot port? if so then a bunch of stuff has got to change b/c the the equation takes into account the depth of the box in figuring port length....if anything, make the port displacement "0" and make your port the length you see in "Lv"....if your using round ports externally, then all you have to do is set the port displacement to "0"...hope that helped some
i likes me some audio stuff...
sorry amatt85, well thanks for your calc, did you download the calc that i updated? i made somechanges to it. all i did was make the tunning go off the whole box vol, minus the subs displacement... i think it looks about right.
In Dash
Rear Flip Down
.....nevermind......
thanks btw :-)
Edited by bangin_explorer
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
i think the actual file we have is different. i tried using the one you have, but i couldnt use it at the time. and i've had one on my comp for a while, then finally got excel to get it to work. think i got it a while back from another site
EDIT: oh yeah and i tried downloading it, but the download wouldnt start. but amatt said what needed to be said at least
Edited by ExpoSport
  • Who's Online   0 Members, 0 Anonymous, 1092 Guests (See full list)
