Sup guys. I just recently performed the big 3. I went
alternator positive to battery positive
engine block ground to battery negative
car frame ground to battery negative
I’ve zip tied all my wires only to believe I was suppose to go from engine block ground to frame ground. So did I screw up and will it effect anything if I did?
Adding the engine to chassis is good in that it will add to the paths back to the battery/alternator, i usually do a big 4 in this way.
I will go alt+ to B+, alt case to neg battery terminal, chassis to battery negative, and finally alt case to chassis on the same ground point.
EDIT: As cars age the ground straps can corrode and break off, so it is a good idea to do that extra run.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
That’s all that’s done to my Avalanche. You’re good.
52 minutes ago, MaxBoom87 said:
Good deal. Great work on the avalanche by the way. I checked you out
:thanx:
