Help with Time Alignment and Speaker Level
Ripkon
2 minutes ago, mothra said:
the passive crossovers are crossed at 3.5kHz. I'd start by crossing there or higher.
I would not cross the mid higher. It will start to beam.  Plug that's way to high for a mid to be playing. Take the passive out. Run it active and cross everything  a bit lower to start
i stated i was running active. the passive is 3.5k i have it active with 31k
Mid 100hz-31.5k
tweet 31.5k
Mid 100hz-31.5k
tweet 31.5k
Ah ok. I misread it.  That would still be to high for my liking.  That tweeter has an fs of 1100. So passing ot even at 2200 or 2500 would be optimal.  Making sure of course you can the tweeter to protect it
Thanks for the info. Should i cross the mid at the same place? Also when you do time alignment do you change the speaker level on either side?
Attenuation  is something you'll need to run an rta  to find out.  But if you use a 24db slope you cross the tweeter right where you cut off the midrange and ot should blend
Gotcha. Im just now getting into a little sound quality and have a lot to learn. Ive been reading as much as i can.
It's what I prefer. More fun but more work in a way
I can see why. Just having a cheap pair of 150$ components sounds amazing with .Flac files. I couldn't imagine hearing an actual SQ build. Thanks for the info you gave me
Never never run a 2 way active or passive setup at a 24db slope. Adjust both mids and highs to a 12 dB slope and leave it there.
It's what I've always done unless I can't get the mid and tweeter blend correctly then I'll cross at a 12db slope and cross the tweeter a few hundred hz higher than I have the mid crossed at.  Just my opinion
  • Who's Online   0 Members, 0 Anonymous, 1891 Guests (See full list)
