dannyboy_916 Posted August 15, 2019 Report Share Posted August 15, 2019 Hopefully someone can help me out here, I would appreciate it very much!! To start off I just recently purchased a Epicenter and I would like to know how to setup with with my amp. What I mean is how to correctly set up my gains and setting in the Epicenter. My setup is nothing big at all. I have an Almani HA 600.4 (300 watts RMS) which was given to me and I have it in bridged mode and a 12 inch JBL GX 1200 watt sub with 250 Watts RMS. I want to know how to correctly set it all up so in the end im not clipping, distorting or killing my sub. Since I got it for a week now ive been slowly able to get it to where I want it, but I want to perfect it. Current setting on the Epicenter is the "Wide" setting is 1/4 way up and the "Sweep" setting is 3/4 up. Bass output is stock at 5 Volts on the inside untouched. Also does anyone know the input voltage that my amp is capable of taking in, I talked to audio control and they said to check on that if not i will have to adjust the bass output on the epicenter? Appreciate it if someone would help out im fairly new to using a Epicenter. Link to comment Share on other sites More sharing options...
Mike4068 Posted August 15, 2019 Report Share Posted August 15, 2019 https://www.stevemeadedesigns.com/board/topic/125198-need-help-with-setting-gains-but-with-a-epicenter/ Link to comment Share on other sites More sharing options...
Mike4068 Posted August 15, 2019 Report Share Posted August 15, 2019 Read d'amores replies. Link to comment Share on other sites More sharing options...
dannyboy_916 Posted August 15, 2019 Author Report Share Posted August 15, 2019 When he says "Turn the amplifiers crossover to its highest setting" he is talking about turning on the LPF on the amp and turn it to what its highest is? Link to comment Share on other sites More sharing options...
Mike4068 Posted August 15, 2019 Report Share Posted August 15, 2019 Yes Link to comment Share on other sites More sharing options...
dannyboy_916 Posted August 16, 2019 Author Report Share Posted August 16, 2019 Gotcha! I will try it and will get back to you! Link to comment Share on other sites More sharing options...
dannyboy_916 Posted August 16, 2019 Author Report Share Posted August 16, 2019 Ok so I have set the gains to my specs, now should I turn off the LPF completely or turn it down to idk 50hz 60hz?? Link to comment Share on other sites More sharing options...
Mike4068 Posted August 16, 2019 Report Share Posted August 16, 2019 Put it to where you want it. You're good to go. Link to comment Share on other sites More sharing options...
dannyboy_916 Posted August 16, 2019 Author Report Share Posted August 16, 2019 Thx! I will try it out for sure! Praying it sounds better this time! Link to comment Share on other sites More sharing options...
Mike4068 Posted August 17, 2019 Report Share Posted August 17, 2019 Let us know how it goes. Link to comment Share on other sites More sharing options...
