So after testing and setting with the dd1 how many people actually play music up to your head unit max  distortion level? I'm set and have set several systems and rarely get that high say 27 to 29 out of 34 tested clean with dd1. Maybe with some music you can get to the max volume but with hip hop most cant. What's your results?
That's how it is. Not all songs are recorded at the same level. So, for example, if you tuned your amp with the - 10db tone and the song is recorded at - 7db you won't be able to use max volume.
