Group 59 recommendation
Can anyone please recommend a good group 59 AGM battery? XS doesn't make one, and I am not finding much online besides big box brands like Optima Yellow/Red top that seem kinda anemic.
When looking for a replacement starter battery for my Mazda I wanted an AGM and looked at Odyssey and Northstar. Went with NS as it was more readily available from a shop in San Francisco.
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Hey man I'm working on a spreadsheet to make it much easier to find out what batteries are compatible besides the factory group 59 for instance.
I noticed that the XS Power D4700 could fit in the dimensions of a Group 59. Just compare the dimensions yourself and see if it works for your case.
https://4xspower.com/shop/12v-agm/d-series/d4700/
Dimensions for a D4700
Length – 9.49 in
Height – 7.48 in
Width – 6.93 in
Length – 9.49 in
Height – 7.48 in
Width – 6.93 in
That's definitely close, but I would need the poles swapped for my wiring to fit.
Damn what are the dimensions of your current battery? I might be able to find a reverse pole of similar size
It's about 9 1/4"L, 7 1/2"W, and about 7" tall.... roughly. It's on the driver side of the car and the positive is towards the aft.
Here is a list of compatible ones you can take a look at, some of them are beyond or below your dimensions so just double check anything before buying.
XS Power:
https://4xspower.com/shop/12v-agm/d-series/d5100/
https://4xspower.com/shop/12v-agm/d-series/d5100r/
(taller by about an inch but has a reverse option and standard)
Some other options
https://4xspower.com/shop/12v-agm/d-series/d1200/
https://4xspower.com/shop/12v-agm/s-series/s1200/
https://4xspower.com/shop/12v-agm/s-series/s975/
Northstar
https://www.northstarbattery.com/product/nsb-agm35
https://www.northstarbattery.com/product/elt-agm35
(both of these are 9 1/2 in length so you might be able to fit them with some adjustments, also about an 1 1/2 taller at 8.5")
Optima
https://www.optimabatteries.com/en-us/yellowtop-deep-cycle-battery/d7525
https://www.optimabatteries.com/en-us/yellowtop-deep-cycle-battery/d35
(both are 3/4" taller at 7 3/4")
Yeah the yellow tops were the only ones I found that are a direct fit. XS wants to sell a billet aluminum mounting plate/hold down with the D3400, which is their suggestion.
I'm about ready to just get something inexpensive up frontand wire it parallel to a 2nd batt behind my seat. I was hoping to avoid a 2nd battery but it's starting to look like that might actually be cheaper than trying to make something fit under the hood.
What car is this for ? Might be a better solution if you are wanting to stick to a single battery instead of two
  • Who's Online   0 Members, 0 Anonymous, 4882 Guests (See full list)
