Upgrade to 2/0 or stick with 1/0?
I currently have about 45' of 1/0 welding wire to replace my current oversized 1/0 shca oversized cca. I'm changing up amps to a taramps md5000.1 or a md8000.1 and want to make sure I can handle the current draw of either of those amps. If I get the 5k I'll have enuff cash to get 45' of 2/0 welding wire ( which is enough for a single run, big 4 and two extra batteries ) . I can get the 8k and use my 1/0 welding wire but don't wanna start a fire lol. Have a 250a alt for now, gonna start saving for a real deal 500a soon. I have two 1000cranking amp interstate batteries under the hood and two interstate marine deep cycles in the back ( that's another upgrade in the future to either upgraded in the back or maybe just two lithiums under hood, not sure yet). I don't demo or compete but like to hurt ppls feelings once in a while and let her rip so I wouldn't be full tilt for too long so I'd probably never pull full amperage either. Probably helps I'd be wired to the sub at 2.67 ohms (and prolly upwards of 4 ohms after rise).
So summary is, use my 1/0 and get the 8k or get the 5k and 2/0 ? I may be able to run dual runs of either , my truck isn't real long (1997 extended cab z71)
Personally I would do a dual run of 0 gauge over a single run of 00. Especially since it sounds like you already have a single run. A dual run of 0 will allow more current flow than a single 00, and be cheaper. Just my .02 ;)
I got oversized 1/0 cca or I'd stick with that but it's inefficient. I can afford the 8k and a single run of 2/0 welding wire which is good for 450a and amp pulls slightly less than that max musical amp pull. That'll get me by till I can get a second run of 2/0. All my old 1/0 will go in my buddies truck since it's same vehicle. So not wasting anything , hate tossing good stuff out.
17 minutes ago, Scotnemily said:
Sorry. Didn’t realize you had CCA. I personally don’t like it, but some people do.
Yeah it's what I had funds for when needed wire lol. Yeah welding wire runs a bit smaller but like bmwking said it is ofc and designed for high draw. I can afford one run now and when taxes come in I have half a dozen Installs lined up so I'll have sum more okay money for my truck.
I understand. I bought some cca wire when I was using the 6 channel PPI amp for my subs. I didn’t realize when I bought it was was getting cca. It worked ok but did start to get corrosion on the ends. I swapped it out once I saw that.
Oh I soldered all my ends when I first got it and here in upper Michigan it made one winter and I had to redo EVERY end with a new end and I crimped and heat shrinked em and they have been fine since. Soldering them is a real PITA also, hard to get everything up to temp to take solder , damn strands would basically melt if u tried to heat all at once , had to heat the terminals, fill it with solder and while solder was liquid plunge the wire into the lug full of solder . NEVER AGAIN lol.
Man it was late when I was doin my math or something! Had something in my cart I didn't see but I can afford to get 4/0 welding wire , how does that compare to car audio wire? Size wise I mean? I only need just shy of 30' and with 4/0 I don't think I'd need a second run for my setup , only the 8k and a will probably get one or two of the taramps 440x4s , may not be the best amp but I HAVE to have matching amps or it'll drive me crazy.
Think I read 600a at 600v for the 4/0, and my longest run from front battery back is just over 10'
  • Who's Online   1 Member, 0 Anonymous, 1274 Guests (See full list)
