image91 Posted March 14, 2020 Report Posted March 14, 2020 Edit: Good day all, can't fit the originally planned 2x Sundown Xv2 15s. Trying to decide between a single Nightshade 15 or two Z 12s. There are pros & cons as always. Both enclosures will fit the vehicle, the NSv4 15 more comfortably (5.0 ft^3 net, 80 in^2 port area vs 4.25 ft^3 net vs 68 in^2 port area). The weight factor is 200 lbs vs 50 lbs, 12s vs 15. Cone-area-wise, the 12s should move more air. FS on Zv5 12 is 33 Hz. Don't know the FS on the softer kit on the NSv4 15 as they have specs up for the spl kit I assume at 35 Hz. Looking to tune to around 30 Hz. Running on a Deaf Bonce Apocalypse AAK-5500.1. Will be requesting the non-spl kit on NSv4. Does anyone have experience with both these subs & can give me some insight? I have used the Xv2 15 before but have never heard The Z or NS series. How do they play tonally? & do they both handle the low end well? Want to play down to 28 comfortably. Thanks!! Original post: Has anyone ever run these woofers in a smaller than recommended specifications enclosure? I currently have around 41.5 x 17 x 24 to work with. Getting these on a sale & wondering if I will encounter any issues running them in a smaller enclosure. Looking at a mono-chamber tuning around 30 Hz. Running around 2500w+ to each. May be able to add 1 ft^3 to enclosure if i custom build an addition to the volume in the space behind the back seat as it is a wagon & the back seat is at an angle. Also may be able to go up in volume by an inch but that would be over the seat height. What's the most compact I can go without sacrificing too much? O_o Any help would be greatly appreciated as always. Thanks!
AaronT Posted March 15, 2020 Report Posted March 15, 2020 Not doing the math in the box. What is the volume of the box you listed and what is recommended?
AaronT Posted March 15, 2020 Report Posted March 15, 2020 But before we get into all that yes you're going to have a compromise if you stick him in an enclosure that's too small those are pretty big subs and they need to breathe so sticking them smaller is going to obviously decrease output I would definitely go to custom box that's going to fit they give you the proper air space but using whatever you have for the time being is it going to be horrible it just not going to be everything they can do
image91 Posted March 15, 2020 Author Report Posted March 15, 2020 Not going to get near the recommended volume in a comfortable manner. Tried fitting volume everywhere I could think of & it was still too small. Considering just waiting til NsV4 15s come back in stock & take one. Won't move more air than the two Xv2 15s but it should do well for a single 15. Apart from that, my other option was two Zv5 12s.
image91 Posted March 17, 2020 Author Report Posted March 17, 2020 Can anyone chime in with regards to 2x Zv5 12s compared to a single Nsv4 15? (with the non-spl kit)
Dragonsyph Posted March 18, 2020 Report Posted March 18, 2020 Pretty sure they are coming out the the NSV5 soon and not sure if they will restock the NSV4. ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA
image91 Posted March 18, 2020 Author Report Posted March 18, 2020 Hmm, is that confirmed bro? Didn't hear/see anything O_o Was being allowed to place an order from my local dealer. Wondering if I should hold or go ahead, especially with the corona situation. Btw, how's the NSv4 18 going? Do you have any links to vids? = )
Dragonsyph Posted March 19, 2020 Report Posted March 19, 2020 10 hours ago, image91 said: Hmm, is that confirmed bro? Didn't hear/see anything O_o Was being allowed to place an order from my local dealer. Wondering if I should hold or go ahead, especially with the corona situation. Btw, how's the NSv4 18 going? Do you have any links to vids? = ) Can't say for sure, i just remember one of there facebook posts talking about it. I do know though that the NSV5 is in the works, not sure when its release date is though. That orion amp blew up from just idling with no power to the sub going lol, i ordered a Salt 4 amp, should be here with in a week or two. Had to be something in the amp because all of my other amps have been working just fine on same electrical. While i had it going the NSV4 pounded like a mad man for sure. It can take double the wattage easy if clean power. Cant wait to get the Salt 4 hooked up which puts out around 6k watts. Should pound like crazy. And that new b knob it comes with has Volt meter, clip light, and thermal light etc. Pretty bad ass. I would go with more cone area (two 12s) but if you cant get a box big enough in there then its a waste. If you can get a box for the 15 thats to spec or close then i would probably pick the NSV4 15" and put around 5-6k watts into it. ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA
kalilac619 Posted March 19, 2020 Report Posted March 19, 2020 NSv4s have been the best subs I’ve owned....I have 2 18s in a 6th order with almost 2 years of taking a beating....what each one is seeing 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Micheal Brown Posted March 19, 2020 Report Posted March 19, 2020 7 hours ago, kalilac619 said: NSv4s have been the best subs I’ve owned....I have 2 18s in a 6th order with almost 2 years of taking a beating....what each one is seeing That's awesome! An automotive enthusiast. https://autance.com/
