Low tuning = lower LPF setting?
Audiohz
So the question is with a box say tuned at 32hz is that bringing the over frequency range down to have top end lpf set at 50 to 60hz ? Box I have now has an sa10 right under 1.0 cubic foot tuned at 32 hz displacement probably has it about 34hz imo but when I set my lpf with my smd cc1 at 100hz to 125hz it sounds absolutely terrible. Once I try dropping down to 60 to 80 it gets a little better. Is this normal for 10’s ported?
why would you even think 100 to 125 hz would be a good lpf point for a sub? i usually don't set higher then 80 and never had really any problem with the sound at that frequency with any size i have used And  i usually port 33 to 34 hz ...  Are you sure you are setting everything right   And what doesnt sound right?
I am using a dd1 and cc1 and going by the manuals.
100 is highest possibly accepted, not ideal. 125, is ridiculously high.
Only way I'd do 100 is at a 18db-24db slope.
I have my mid 6.5s at 80 up at 18db and sub 80 down at 12db.
Shoot for 80 down at 12db slope it'll get a bit higher than 80 through but not much
My slope is 24db . The subs are two sa10 rev 2 on a sundown saz 1200 set with the dd1 for -10db . The only way it sounds good to me and my Cousin that I’m tuning for is below 56hz. SSF set to 28hz .
  • Who's Online   0 Members, 0 Anonymous, 745 Guests (See full list)
