Nitrousbird Posted August 15, 2020 Report Posted August 15, 2020 I have a Polk D4000.4 in my wake boat that was running 4 Exile Audio SXT65 tower speakers for the last 8 years. Amp is rated for 125x4 RMS, which is how I was running it, which was the rating of the speakers. I had it tuned to the bleeding edge previously (using my SMD-DD1, also have a CC1 for the crossover). I upgraded head units this year, tested for distortion (0), tuned it with the boat off, no H/U distortion - batteries always fully charged as I have an onboard 20amp dual bank charger. Our last outing I was wakesurfing, had it cranked and all of a sudden my tweeters distorted like mad. Wife driving and it happened for a bit before turning the volume down. Resulted in 3 blown tweeters along with one blown woofer. I am guessing I clipped hard. So now I am going from those 4 tower speakers to two much larger Wet Sounds REV 10's: https://www.wetsounds.com/product/REV-10-B-FC-SS-V2 For the remainder of the season, I plan on just running this amp bridged @ 4ohm, which is a claimed 400x2 RMS. These speakers are rated for 300RMS but it is well known they can take up to 500. I also don't believe this amp puts out 400x2 bridged, even though Pasmag years ago rated it at 140x4 at 14.4V (they never tested it bridged). My question: - Should I tune it with the motor running or when the boat is off? I have always done off previously. I don't have any alternator whine or other noise in the system running or off; I wired everything from scratch when I put my original setup together. I will cove crank it when off and crank it when surfing, so it will see max use case for both scenarios, so I want to tune for the situation that is most likely to have distortion. - I tried tuning it tonight (my speakers aren't here yet) on the bridged terminals and could not get any distortion on track 4, 1kHz @ -5db. I could measure distortion, that went away turning the gain down, at 0dB. I find that odd that this amp has no distortion bridged at -5dB but does un-bridged. Yes, crossover was set to full, loudness off, EQ flat, H/U @ 100%, etc.
1point21gigawatts Posted August 15, 2020 Report Posted August 15, 2020 It doesn’t matter. Same thing. The rca signal would have the same voltage either way. That’s what the gain has to match. And the crossovers just need to sense a frequency. So it doesn’t matter if the alternator is on or not. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
BassMunky Posted August 15, 2020 Report Posted August 15, 2020 Wouldn't it be louder? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
CstrokerV Posted August 15, 2020 Report Posted August 15, 2020 I do mine whichever The car happens to be at the time lol my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
