Replace stock HU or use a LOC?
19 minutes ago, Mattc43 said:
Ok I’ll just get the amp pro. Thanks
That's your best move for now, a DSP is something you can easily add later too. There's a lot of info here where you can learn about DSP's, read up. You need more info than I can provide in a post. I'm no pro at DSP's, I haven't started using them until 5-6 years ago so they're still semi new to me too. There's a wealth of knowledge on the board tho.
  • 5 weeks later...
Amp pro will not work with my car. I’m just gonna get a double din touchscreen head unit
There's other ways to do it then amp pro
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
On 9/6/2021 at 5:32 PM, CorNut said:
What you want is an AmpPro, it gives you a clean signal to add amplifiers or a DSP
Search for part# AP4-TY11
It's not the cheapest option but it eliminates any factory radio crossovers, it leaves you with clean outputs & lets you adjust door chime volume if that goes through your radio (I'm not sure about your vehicle), plus it has a knob you can use as a bass knob for your sub amp. It's worth it's weight in gold if you want to stay with a factory look/interface.
If you're going budget, check out the Dayton Audio DSP-408. I recommend doing a DSP before your amps if you're doing mids and highs as well. If you're only doing subs, it isn't as crucial.
Can you link me to this AMPPRO gadget?
Edit- ive never heard of this. Please link me this "clean" out put converter. I want to see what its about
06 Charger
Pioneer double din
Xs power d3400
I don't understand your sarcasm? Some cars have factory crossovers, fake engine noise etc.. Are you making fun of me for saying an item that removes that stuff as being a clean signal? If you feel like there's a better word than "clean" for what I'm describing, good for you.
Awesome. You actually got that.  Well done. And there is far and few between "locs" that really give you any TYPE of "clean" signal. But, hey, glad you caught on to that. All that said, where is the link my man? Zero sarcastic shit there. Show me. Where is this "item"??? Link me.
I sent it it's the Crutchfield thing
06 Charger
Pioneer double din
Xs power d3400
Cool, good luck with that.
Edit- looks like your going to buy 500 dollars of shit to keep factory controls.... the actual LINE OUTPUT CONVERTER, is what part again.....???  Just 2 channels eh... good luck.
Ya, you will have unwanted noise. Guaranteed. Or, maybe 500 bucks will give you an actual clean signal out, and also, defeats oem signal lose at upper volumes, or, gives you any type of signal, below 40hz.... buy it all, get it in, and let us know.
Seriously, good luck. Hope it works out
  • Who's Online   1 Member, 0 Anonymous, 1821 Guests (See full list)
