2 sets of speaker terminals, i can only read one at a time with multimeter. did voltage calculations to figure out what i need my gain to read to get 1000 watts of output since i dont have an aftermarket alt.
question is, is the voltage i read from one channel split so i need to split my final voltage to get the right gainset? because its still monoblock. thats the only reason im asking
It is only a single channel amp. So your good just getting it from wherever you can.
It's full bridge those 2 terminals are internally connected
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
I have a stock alt but my stock is a 160a
06 Charger
Pioneer double din
Xs power d3400
my stock alt is 150 and a stock agm battery since its a 2020. problem is the alternator has already been overworking because it started turning black. although that mightve been fault of the old amp, wiring kit etc as well. i know i did run ac and the subs at the same time too not thinking about it.
but there isnt such specific information out there even no matter how i word it. usually just get keyword triggered and get random stuff that sometimes is even unrelated to what im asking.
i see you are using the d3400 but a different main? do you have a ground running all the way up front too?
Both of my battery's are in the trunk but they are both agm battery's  the duralast is 76 ah and the d3400 is like 80 ah or something like that
06 Charger
Pioneer double din
Xs power d3400
I have a build log it's Alice and the wonderland
06 Charger
Pioneer double din
Xs power d3400
I have no idea when my alternator was changed so it could go out any min but I been looking around for the right high output for me
06 Charger
Pioneer double din
Xs power d3400
What year make and model do you have?  Maybe i can help you look.
