It starts FINE with RS, but won't start with the key .... it usually turns over, STARTS to about 1k RMP, then immediatly dies .... :(
this is AFTER i took it to the shop to fix it the other day when it wouldn't start with either ...
any suggestions?
and sorry for all the topics in security center
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
i did not install it though a shop did! should i just have them look at it yet again? thx!
~Matthew
yeah but i took it into them sunday .. yesterda y.. let me explain
i got it installed friday, then the RS AND key didnt work .. so took it in yesteday they said they bypassed something and the key should ALWAYS work .. now the RS works but the key doesn't .. :( ill just take it in again
~Matthew
I bet they didnt program it right and the system dropped your key. your gonna have to get it to the dealership somehow and get them reprogramed
Edited by Chode69
NoFearX18 said:
I'm not sure on your car but GMs have a security feature that turns off the fuel pump if the car is started improperly. Thats why remote start units use a bypass to get around this. The key ignition must also be wired into the bypass since you cut the factory wires to install it. It sounds like they didn't bypass it at all the first time and have now bypassed it with the remote start only but not the key.
I highly doubt that.
They wired up your transponder bypass wrong, car is seeing two keys and shutting down. Like I said in your other thread.
It's a transponder bypass with a key, so no need to cut the factory security wires. It will use a ring around the key cylinder.
Like I said in his other thread they more than likely have the ignition wire hooked up off of the transponder... so everytime the key is being turned the ignition wire is going hot and activating the bypass... so the car is seeing two keys at that time and shutting down.
Edited by Shyne151
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
Shyne speaks the truth !
I do however have some q's
Did they ask you for another key ?
if so did you get an extra one programmed or just cut ? there is a difference.
if it is a transponder bypass and you supplied a working key then shyne is correct
If not give me more details and between us all we can sort it out!
out of any, Id agree with shyne. But overall, you should take it back to them till they get it right or ask for your money back/credit. you paid for a service. it should be working correctly, especially after a return with a problem. Do these guys check that its working correctly before they give it back to you? I cant imagine they wouldnt.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
