A little about my car, its a 1983 Chevy Impala 4 door big body. I have a Alphasonik PMA600HC Amp, 2 12inch MTX Jackhammer JH4512X2D, a lightning audio LSD10DT-03 Capacitor, i also have 2 Boston SL95 6x9's, and 2 Boston S75 4x6's, the HU is a Pioneer Premier DEH-P980BT. The Problem i am having is my headlights Dim extremely bad at night time and when i am stopped at a light with my system on my car will die, i just put a new battery in and i installed my capacitor from my old system. What can i do to fix this.
I am just getting into doing my own installs so i dont know to much about it.
big 3, upgraded alt.
ditch the cap.
2015 Honda Civic LX 4dr | 110k miles | Stock
1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Okay, I had that problem too until I looked up how to upgrade the "big 3"
#1
Run atleast a 4 gauge wire from your - battery terminal to your vehicle ground spot.
#2
Run atleast a 4 gauge wire from your vehicle ground spot to your engine block ground spot.
#3
Run atleast a 4 gauge wire from your + battery terminal to your alternator + output terminal. Make sure to fuse this wire as close to the battery as possible.
If this doesn't totally solve things, you may want to think about adding a small deep cycle dry cell battery in your trunk.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
#1
#2
#3
X3
This means your voltage is dropping around 9 volts lucky something has not went up in smoke not just talking about your audio equipment!
Do the big 3 I would use 0 gauge and never have to touch it again do that and try a missing link it also ups your voltage
Oh and kick the cap to the curb
Werd!
I have an 80 Impala :wub:
like previously stated, upgrade your underhood to 1/0
make sure amp is grounded to FRAME and not the trunk floor...
there are rubber bushings/body mounts that seperate car body from the frame
chances are you alt may be toast already, take it to get checked out
I use a 260amp Iraggi alt in mine
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
got any pix of your install?
