Can it be done
gewaun
it'll change your tuning slightly, but its negligible. you'll want to move the extra baffle to the top instead of the front, but other than that, I'd say go for it. just by my rough calculations, it seems that box is tuned fairly high (almost 40hz). if you are just playing regular music, and not much rebass, it'll more than likely sound decent.
This page is crispy_chick3n approved.
© crispy_chick3n inc
On 4/21/2025 at 4:10 PM, gewaun said:
Using this design is it possible to change to subs up with port in theimage.jpeg.148eb2d4ba4abe39c0c24bad39498f49.jpeg same place. Can it be done? What changes do I need to make it's for 15's.
This design is already for 15s looking at the sub cutouts, you just need to do a double layer baffle on top and you should be good to go, you don't need need a double layer baffle where the subs are now.
On 4/21/2025 at 10:26 PM, gewaun said:
Box is from resilient sounds webpage says tuned to 34.5hz. Can anyone with knowledge check for me.
punching those numbers into my box calculator gives me 35hz without any displacements after displacement its 36.2 as its modeled. 36.7 subs on top. not bad, but still a little high for my taste
  • Who's Online   1 Member, 0 Anonymous, 772 Guests (See full list)
