Please I need help. I have an 07 Cadillac Escalade with a c-pillar 4th order. 2 dc audio level 6 18s on 2 deaf bonce asa 8000.1. Sealed 6cu ported 12cu 240 sq port tuned up 47. It sounds amazing and deep from 28hz-42hz but the coils get really stinky really fast. Voltage only goes down to about 14.3 volts and there is no clipping. But my real question is did I make the wrong choice by putting them in a 4th order box. Any help would be greatly appreciated thank you
IMG_0323.heic
Have you checked with an oscilloscope to make sure the subs are getting a clean signal?
2015 Honda Civic LX 4dr | 110k miles | Stock
1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Haven't done that. But even full tilt the clip light doesn't blink or flicker at all
That's great. Is it accurate? Hook up an o-scope and verify.
How much are the drivers moving?
There's kind of a sweet spot. Box too restrictive and they won't move enough to cool. Too much and the coils will hop out of the gap and lose the inductive feedback - dropping the impedance and turning into a heater
Clipping would cause it too. Signals are compounded. Just because the amp's clipping light isn't coming on doesn't mean the input signal isn't clipped - worth a check as well
And I also don't want to discount a wonky signal either. To this day, I'm not sure what causes it, but something in my setup was feeding I think either a hard DC offset on my signal, or an ultra high frequency interference to my sub and it would go from room temperature to stinky coil in seconds even at low volume. It was the strangest thing.... My point is: Don't rule out a weird signal or a bad component either.
  • 1 month later...
  • 4 weeks later...
I just made a ported box for 2 dc audio level 6 18s and it also stinks, I push them hard with a deaf bonce 12.5k each though
