trainman0978 Posted June 21, 2008 Report Share Posted June 21, 2008 cuz somtimes when i put solder on it it just drips down When it does that , put the connector on the end of the wire, then take a pic or a nail or something and push it down into the wire that is inside the connector, then pull it out. All you are trying to do is make the wire spread out into the connector. Don't force it, and don't mess up all the strands of copper , just stick the nail or whatever into the center and pull it out, not only will it spread out the wire it will give you a nice cavity for solder to fill and the liquid heated solder will penetrate the strands better. 2007 Toyota FJ Cruiser Voo Doo Blue my upgrades and "build" thread. My Kulicki Box Build -Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars -Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash ) -JL Audio 2 way Component set XR650CSi - Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box. -Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio -All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0, -270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum- -2 Powermaster D680 Powercells in back FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz. Shoehorn, BFH, forklift,duct tape and some zip ties Link to comment Share on other sites More sharing options...
ma18 Posted August 13, 2008 Report Share Posted August 13, 2008 use a phillips screw driver and a hammer works every time 18" ma audio p180xl "old skool" kicker 652xi impulse 200 watt la amp (for tha highs) pioneer deh-p3000IB hu 1 power run of 4 Ga 1 farad stinger cap rf 200 amp breaker all monster wires 95' cutlass supreme Link to comment Share on other sites More sharing options...
usmc7980 Posted August 13, 2008 Report Share Posted August 13, 2008 I normally use compression fittings with the set screw from Knukonceptz. What I do is tin the end of the wire then fill the terminal with solder, insert the wire. tighten down the set screw then solder the head so it can't back out. Link to comment Share on other sites More sharing options...
Shyne151 Posted August 13, 2008 Report Share Posted August 13, 2008 use a phillips screw driver and a hammer works every time what? -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000 Link to comment Share on other sites More sharing options...
trainman0978 Posted August 13, 2008 Report Share Posted August 13, 2008 x2... spend twenty bucks and buy a torch or mini torch. If you got the coin to spend on 0 gauge wire, you ought to be able to afford to finish it off right. I know my first couple of 0 gauge wire solder jobs were sloppy, but I learned by trial and error and from reading on here. Do it right after you learn and be done with it . 2007 Toyota FJ Cruiser Voo Doo Blue my upgrades and "build" thread. My Kulicki Box Build -Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars -Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash ) -JL Audio 2 way Component set XR650CSi - Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box. -Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio -All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0, -270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum- -2 Powermaster D680 Powercells in back FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz. Shoehorn, BFH, forklift,duct tape and some zip ties Link to comment Share on other sites More sharing options...
chewie Posted August 20, 2008 Report Share Posted August 20, 2008 i use channel locks and then i solder it and heat shrink it. i grab the wires plastic real close to the connector with channel locks to avoid melting during soldering. 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car... Link to comment Share on other sites More sharing options...
getonerd Posted September 26, 2008 Report Share Posted September 26, 2008 i found this at delcity.net if u can see the vid here the link 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS Link to comment Share on other sites More sharing options...
Airborne Posted September 26, 2008 Report Share Posted September 26, 2008 i found this at delcity.net if u can see the vid here the link I wonder where you get the pellets. Looks like a great idea. Link to comment Share on other sites More sharing options...
