flashlight_65 Posted June 11, 2008 Report Posted June 11, 2008 whos added a chip for those extra horses or gas mileage? if so any problems? fill me in please. i debating on getting one just want your opinion My builds: my caddy my 'hoe friends impala
str86diesel Posted June 11, 2008 Report Posted June 11, 2008 More Power equals more fuel. Chips will not conserve fuel unless they cut back on fuel, thus removing HP's. 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
ptcary Posted June 11, 2008 Report Posted June 11, 2008 Depends on the car. Some benefit more than others. I have a non-turbo PT Cruiser, and chips range from +8hp to +17hp on a dyno. Mileage doesn't really change. And the better ones also work to change the automatic transmission computer program. PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
str86diesel Posted June 11, 2008 Report Posted June 11, 2008 The key is this....adding a chip, doesn't change the efficiency level of how the vehicle burns fuel. The only way to change fuel mileage is by changing driving habits, gaining fuel burning efficiency, or cutting back fuel. If your injectors are rated to flow a certain rate of fuel, as long as the pump keeps the lines full of fuel, those injectors will continue to flow at their rating amount, meaning you will burn the same amount of fuel. To gain HP, you need both air and fuel. For a fuel injected vehicle to maintain it's Air/Fuel ratio, as extra air is added, the pump will equal that air ratio by adding fuel. In NO WAY is this cutting back fuel, or gaining effficiency. It's actually forcing the vehicle to burn additonal fuel. 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
flashlight_65 Posted June 12, 2008 Author Report Posted June 12, 2008 could adding a chip harm the engine? My builds: my caddy my 'hoe friends impala
A&W ROOTBEER Posted June 12, 2008 Report Posted June 12, 2008 chips never really work for fuel, if you want try looking for a intake kit..a friend has one on his truck and it added about 2 more miles to the gallon and he never changed his driving
loganberry Posted June 12, 2008 Report Posted June 12, 2008 sct ftmfw imo, my dad has one on his truck, he gained 120 horses and 2.4 miles to the gallon and didnt even really change his driving at all, so that whole chip and no gain thing really dosnt work for me, sct is all we have ever used and has ALWAYS worked for us, my brother has one of the fastest 6.4l's in california too and even gained mpg from a sct tuner...i would look into sct for sure if your going to get one My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
David Posted June 12, 2008 Report Posted June 12, 2008 Um just go away NOOB you have no Idea what your talking about.
loganberry Posted June 12, 2008 Report Posted June 12, 2008 Um just go away NOOB you have no Idea what your talking about. he asked for chips that do good and i posted some that i have had quite a bit of experience with, how am i a noob if i have had plenty of experience with the item? My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
A&W ROOTBEER Posted June 12, 2008 Report Posted June 12, 2008 he asked for chips that do good and i posted some that i have had quite a bit of experience with, how am i a noob if i have had plenty of experience with the item?dont worry man, he eiter needs pepto bismol or some pu$$y and he'll stop barking like a dog in heat..lol
