Big P Posted June 20, 2008 Report Posted June 20, 2008 Thats lame. I never did like AZ compressors. I know 60 impalas will get off the ground with a RS6 and 200 psi. Ive seen them clear cigarette packs with 150 psi. It just depends how the car or truck is set up and the location of every thing. I can get 1 wheel off the ground a tinny bit when hitting a side at 200 psi with RS7's It takes a ton of air to get the stupid thing moving with the angled A arms and v6 in front of the A arms.
02Blazer Posted June 20, 2008 Report Posted June 20, 2008 Major. Im not sure about the helium. I know every one preaches that hes doing it off of the compressed air. Ill look into it later tonight. B. a properly set up bagged vehicle will ride better than stock and give you years of trouble free service. very true , if your bag job was installed PROPERLY and good fittings were used, you should have NO problems !!!!!!!!!!!
02Blazer Posted June 20, 2008 Report Posted June 20, 2008 Thats lame. I never did like AZ compressors. I know 60 impalas will get off the ground with a RS6 and 200 psi. Ive seen them clear cigarette packs with 150 psi. It just depends how the car or truck is set up and the location of every thing. I can get 1 wheel off the ground a tinny bit when hitting a side at 200 psi with RS7's It takes a ton of air to get the stupid thing moving with the angled A arms and v6 in front of the A arms.air zeniths suck !!!! those pieces of crap blow piston seals and burn pistons all the time , viar are the only good compressors, unless you got big bucks to buy an oasis !!! i would love to have one of those thats funny you said you got 1 wheel of the ground a TINY BIT !!!!!! ha ha
B Slaps Posted June 20, 2008 Report Posted June 20, 2008 air zeniths suck !!!! those pieces of crap blow piston seals and burn pistons all the time , viar are the only good compressors, unless you got big bucks to buy an oasis !!! i would love to have one of those thats funny you said you got 1 wheel of the ground a TINY BIT !!!!!! ha ha that is the cadillac of all compressors I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
02Blazer Posted June 20, 2008 Report Posted June 20, 2008 that is the cadillac of all compressorsthe only downside to that compressor is that it sucks ALOT of juice, like a 3000 watt amp !!!! but i would run 4 if i could !!!!!!!!!!!!!!!!!!!!!
B Slaps Posted June 20, 2008 Report Posted June 20, 2008 the only downside to that compressor is that it sucks ALOT of juice, like a 3000 watt amp !!!! but i would run 4 if i could !!!!!!!!!!!!!!!!!!!!! i still got a few things laying around for bags dual 3/4 conti tech bag 4 ply. few helium tanks 6 gc extreme 3/4 800 psi valves. pressure switches ect.was thinking i could sell some of this stuff on here??? I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
02Blazer Posted June 20, 2008 Report Posted June 20, 2008 i still got a few things laying around for bags dual 3/4 conti tech bag 4 ply. few helium tanks 6 gc extreme 3/4 800 psi valves. pressure switches ect. was thinking i could sell some of this stuff on here??? i myself would never use helium cause you cant tell much you have in the tank, you have to weigh the tank to see how much u have left, f-ck that !!! i used to use nitrogen , in my opinion , the best way to go if your gonna go with bottled gas . how did you like those GC x-treme vavles ?? i haven't heard that good of results with them, i would go with SMC or DANZ or maybe ASCO and maybe run 1'' valves..
02Blazer Posted June 20, 2008 Report Posted June 20, 2008 i still got a few things laying around for bags dual 3/4 conti tech bag 4 ply. few helium tanks 6 gc extreme 3/4 800 psi valves. pressure switches ect. was thinking i could sell some of this stuff on here??? 6 valves ???? was that just a front set up ?? 2 fills 1dump on each front wheel ??
B Slaps Posted June 20, 2008 Report Posted June 20, 2008 i myself would never use helium cause you cant tell much you have in the tank, you have to weigh the tank to see how much u have left, f-ck that !!! i used to use nitrogen , in my opinion , the best way to go if your gonna go with bottled gas . how did you like those GC x-treme vavles ?? i haven't heard that good of results with them, i would go with SMC or DANZ or maybe ASCO and maybe run 1'' valves.. the gc's are good they never stick. i had a bunch of the danz the boxes kept falling off the top( too much banging around ) the smc's i believe are the ones that make that weird chirp noize. i got a hook up on the stuff to this day cause me and my buddy have bought hella stuff over the years. i kinda got out of . he still has a car on bags struts that is...... the pressure regulator usually works pretty good for knowing how much psi you have in your tank and oen for your air tank also. but a big bottle dosent last long thats why i had 4 in my last truck I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
B Slaps Posted June 20, 2008 Report Posted June 20, 2008 6 valves ???? was that just a front set up ?? 2 fills 1dump on each front wheel ?? yesir. 600 psi is real loud. one hit 53 inches. isint as good as the daddys customz toy...... hops all 4's 5 feet one hit. insane! I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
