Battery Terminals
Alright I jus bought a PowerMaster D3100 and some Knuconceptz battery terminals http://www.knukonceptz.com/productDetail.cfm?prodID=KBT-30N but the screws the battery came with wont allow the battery terminal to fit, does anyone know where I could find some screws that will fit and work? Ive tried at work at Lowes and I cant find anything :( Thanks if ya can help :)
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Looks like you need the posts for the knuc and the power master is a bolt system. correct? In this case they make screw on post for the battery which should fit you knuc terminal.
Try auto zone or even walmart.
MLA
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
do you need something like this?
DC.jpgDC POWER
I almost bought those. these seemed like a better setup. sorry cant offer ya more than that. send those you git back and try these.
parts express
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
yup sumthin like that :D
2007 Chevy HHR LT
UNDER CONSTRUCTION
wouldn't it be easier to use the bolts and heavy duty ring terminals? I have some of the Kinetic posts but use the bolts because it is easier and looks better in my opinion.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
All I used were ring terminals and the bolts that came with the D3100. Works perfectly. No need to buy terminals.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
+100
Bolts and heavy ring terminals are cheaper, offer better contact area and have less resistance. Send those post blocks back.
  • Who's Online   0 Members, 0 Anonymous, 4089 Guests (See full list)
