MTX 1501D @ 1 Ohm?
Benji0687
I need to know whether or not my mtx 1501d amp will be stable to use daily at 1 ohm. I'm going to be running all 1/0 with a yellowtop under the hood and a kinetik batt in the back, so power wont be an issue. i'm gonna hook up two Pioneer Premier W3000SPL (dual 4 ohm) subs in a ported box. Any help would be really appreciated!
1989 Chevy Caprice Classic
350ci V8 High Performance
JVC Arsenal HU
JL XR series components
Infinity Reference 6x9s
Pioneer Premier 4-Channel
Clarion 2-Channel
Rockford Fosgate Series 1 2-Channel
Fusion 2000.1D
MTX Crossover
RF, Knu, Kicker, and Monster wiring
NVX VCW 12in. Sub **Won on here from the Sonic contest!**
*Build log coming soon!*
Starting all over pretty much which the gear listed...lost almost everything I had, including my life. Never take life and what's in it for granted.
Is it rated @ 1ohm?
yep my homie has that same amp and was running it at 1 ohm and wondered why it kept going into protect after 15 minutes of play. it's only 2 bro.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I know its only rated at 2 ohms, but i didn't know if it could handle the lower ohm load. how would you guys hook up two dual 4 ohm subs to that amp? any help with this is really appreciated.
JVC Arsenal HU
Clarion 2-Channel
Fusion 2000.1D
MTX Crossover
I know its only rated at 2 ohms' date=' but i didn't know if it could handle the lower ohm load. how would you guys hook up two dual 4 ohm subs to that amp? any help with this is really appreciated.
[/quot
with two d4s you can only run that amp at 4 ohm and that's only 750rms x 1 at 4 ohm. so not much juice. you can wire both subs in series and have them running at 8 ohm apiece and bridge them to 4 ohm together. see if you can get some D2s.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
