NightCrawler Posted July 5, 2008 Report Share Posted July 5, 2008 what is happening im blowing fuses right and left i checked all my connections theres no shorts or ground faults nothing i can find. i turn it up about half way or lil bit more and after about 5 min it blows my fuses for my sub amps im useing 40 and 60 amp fuses .i just dont get it Quote Link to comment Share on other sites More sharing options...
99vic Posted July 5, 2008 Report Share Posted July 5, 2008 (edited) what is happening im blowing fuses right and left i checked all my connections theres no shorts or ground faults nothing i can find. i turn it up about half way or lil bit more and after about 5 min it blows my fuses for my sub amps im useing 40 and 60 amp fuses .i just dont get it why is it using different fuses or do you have 2 amps with different fuses? i have never seen that before if its 1 amp different fuses, also you could be trying to draw to much power, i had that problem before, my amp was up to high and it kept blowing fuses i turned it down and it stopped. try re adjusting your amp Edited July 5, 2008 by 99vic Quote REST IN PARADISE BIG RICH (Sqmonte) never forgotten Why do you guys ALWAYS dispute on NUMBERS????? It's such a played out argument, so fucking annoying.... It's 12 fuckin 15's.... It's louder than you... Shut the fuck up... /Rant I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!dont buy from knowledge he will scam you. http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/ Link to comment Share on other sites More sharing options...
EricM9104 Posted July 5, 2008 Report Share Posted July 5, 2008 what amp? Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
NightCrawler Posted July 5, 2008 Author Report Share Posted July 5, 2008 why is it using different fuses or do you have 2 amps with different fuses? i have never seen that before if its 1 amp different fuses, also you could be trying to draw to much power, i had that problem before, my amp was up to high and it kept blowing fuses i turned it down and it stopped. try re adjusting your amp well i have 4 ga wire runnig from my batt to a multiple fuse block and 4 ga wire running out to each (2)amp useing same size fuses Quote Link to comment Share on other sites More sharing options...
audiofanaticz Posted July 5, 2008 Report Share Posted July 5, 2008 what amp? x2? What amp is it? What subs are they? What voice coils are the subs? How are the subs wired series/parallel/both? What is your final ohm load at the amp? What is your gain set at on the amp? What headunit do you have? Quote Link to comment Share on other sites More sharing options...
99vic Posted July 5, 2008 Report Share Posted July 5, 2008 (edited) well i have 4 ga wire runnig from my batt to a multiple fuse block and 4 ga wire running out to each (2)amp useing same size fuses yea id check my gains,i had the same problems a while back with my amp blowing fuses it turned out that the amp was up to high i turned it down and it solved the problem, Edited July 5, 2008 by 99vic Quote REST IN PARADISE BIG RICH (Sqmonte) never forgotten Why do you guys ALWAYS dispute on NUMBERS????? It's such a played out argument, so fucking annoying.... It's 12 fuckin 15's.... It's louder than you... Shut the fuck up... /Rant I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!dont buy from knowledge he will scam you. http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/ Link to comment Share on other sites More sharing options...
NightCrawler Posted July 5, 2008 Author Report Share Posted July 5, 2008 it doesent blow the fuses on the amps just my in line fuses i have 4 alpine type rs 4ohm 2 power acoustik 2000 watt amps the subs are are wired parralell Quote Link to comment Share on other sites More sharing options...
NightCrawler Posted July 5, 2008 Author Report Share Posted July 5, 2008 yea id check my gains,i had the same problems a while back with my amp blowing fuses it turned out that the amp was up to high i turned it down and it solved the problem, i have the amps 3/4 turn up Quote Link to comment Share on other sites More sharing options...
Derrick824 Posted July 5, 2008 Report Share Posted July 5, 2008 If they are true 2,000watts then a 40a or 60a fuse ain't gonna work. Even if thats max power and they're only good for 1,000watts rms a 40a or 60a still won't be good enough. You need to check your owner's manual for the proper fuse sizing for those amplifiers. Quote Link to comment Share on other sites More sharing options...
jmsonoma03 Posted July 5, 2008 Report Share Posted July 5, 2008 x2?What amp is it? What subs are they? What voice coils are the subs? How are the subs wired series/parallel/both? What is your final ohm load at the amp? What is your gain set at on the amp? What headunit do you have? read what he said what size fuse does the amp require what size fuse are you using i think 4ga is a bit small for that much power i bet the fuse you are using is to small probally a 60a and the amp is drawing to much current throught it poping it. Quote Link to comment Share on other sites More sharing options...
