Are you taking + reading from 1 amp and -reading from the other amp? you did not forget the speaker wire between amps did you?
the wires were on. is that how it goes? even tho both negatives on one amp are connected to the other? cuz i dont think i tested it that way
http://www.sundownaudio.com/SAZ-3000D.pdf
DC.jpgDC POWER
just set it to 5/8 gain and be done with it.
lmao
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
still no solid reading. wouldnt read above 95 volts. then i heard the amp buzzing. gain went all the way up. used bass boost to see if i could get a higher reading and i didnt
Measure voltage from Master + to Slave + when strapped (slave + is the load negative).
that's the first way i did it. maybe i have a cheap meter? i'll try it again tho
Unloaded AC voltage readings aren't always the best either - hook it up to the speakers and use an AC current clamp / AC volt meter at a known impedance (since you have voltage and current you know that).
i dno if i did somethin wrong...well i guess i must have, cuz i got it to read just under 110 volts this time. and i dont think i have a current clamp, tho i'm pretty sure my brother does. he lives about a half hour away but ima try to get it from him sometime.
and jacob ima PM you a couple questions real quick too
