Thats what i thought to thax man.
You will need to run it to a switched 12V source, otherwise it will stay on all the time, and could eventually run your battery(s) down. Any cicuit on your fusebox that is hot only when the key is in the "on" position will work fine.
Are these volt meters accurate?
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
The one on my RF CPCC1 is only off by 0.01.
Some are good some arn't that great.
Same storie- you get what you pay for.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
what ied do is wire the blue wire to the red wire on ur headunit, the red to the yellow wire on the headunit, and black on the headunit and should work that away thats how ied do it but then again wont that register off the front battery how would u kno about the back battery or buy 2? ive been wondering this for a while
You have alot of options to work with.
You can grab the power rite off you ignition wire.
I have a relay on my remote wire for a hard positive so I would probly just hook it up to the remote turn on lead for my amps.
  • Who's Online   1 Member, 0 Anonymous, 1295 Guests (See full list)
