I'm designing a ported enclosure for 3 BL 10's. I Have a net volume of 1.85 cu.ft and tuning to 32Hz. What port area should i have for this and what would the length be.
Thanks
Previous: 1988 Nissan Patrol
Rockford T800.4
Rockford T1 15 (sealed)
Rockford 6.5 Components
Current: 1997 Jeep Wrangler
Build goals...
1x RF P300.2
4x Hertz HCX165's
Built Completes :)
Alpine 9886 Headunit
RF P300.2
RF P500-1bd
2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz
4x Hertz HCX130's
Current comment...
Satisfied for the moment, focusing on performance upgrades
If I did the calculator right port area should be 80.99 inches minimum, if the port is a square then it would be 9 in square, and 107.8 in.
I think this is all right, give it a shot yourself, if you don't want the port to be a square ask more specifically the dimensions you want.
Port calculator
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
By the way, I forgot to link where I got the specs for that sub.
Fi sub specs
Seriously though, reply back as to what you would prefer as port dimensions, just make sure they sum up to a area of 80.99 inches square.
Proud DC owner
Fi sub specs
81sq.in is what I would use on a 5 cube box tuned to 40ish... :o
Unless he means 1.85 cu.ft per sub thats WAY too big.
Good rule of thumb is between 10 and 15 sq.in per cu.foot. Then make it about 18" long and go for gold :)
10.x volts fo' life!
Is that 1.85 cubes per sub or total for all 3?
:huh: I'm just now actually registering what I just did and 1.85 total cant be right... That is a tiny box for 3 of them damn things...
Disregard all that calculating I tried to do earlier and lets wait till this guy replies back to be more specific, I don't think all those calculations I did are right. :nea:
Proud DC owner
It was 1.85 cu.ft for all 3 subs. I'm settin the challenge of getting max sound out on min space.
I know on Sound Sol forum they say 15 inch^2 of port area, but i dunno if that'd be 45 for 3 subs...
Rockford T800.4
Build goals...
1x RF P300.2
4x Hertz HCX165's
Built Completes :)
RF P300.2
RF P500-1bd
4x Hertz HCX130's
Current comment...
You tune a port for the box, not for the subs. It wouldn't matter if you have 3 subs in that box or 1, the tune would be the same if the internal volume and port size & length were the same.....
So- I think you would be better off with all 3 sealed or just 1 ported. Just because you can stuff the speakers in there doesn't mean it will be louder or sound better.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
