of course i will use both neg and positive for each amp
2 18'' fi btls fully loaded
2 sundown saz 3000d
1 iraggi 200 amp alt
3 powermaster 3100d series batts
11.75 cuft wall after displacement tuned to 31.08 hz
ok i added this pic to show that you need a fuse b4 the second set of batteries but yes + to + and - to - of each battery and then + from battery to amp/s, and - from battery to amp/s
but if you want to save some wire just ground the rear batteries to the chassis of the vehicle.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
yes...assuming they are all 12v batteries. All positives together and all negatives together
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
well i thought i would put my fuses from the back batts to the amps? i only have 2 fuses with 2 fuse holders. but i will deff prolly just ground out batts instead of running the two neg runs from the front. never thought of that before.
Edited by Krice420
2 sundown saz 3000d
your amps should have fuses those will protect the amps. the fuses on the wire are to protect the rest of the vehicle if your + wire should short out. If you dont fuse b4 the second set of batteries ( rear batts) the front fuse will/may pop but the wire will still be live from the batts in the back which = disaster aka fire!
Scientia est Vox
well my sundowns say i need an external 300 amp fuse. so thats what i got 1 for each amp. so now im kinda stuck on what you mean. if i gotta put one before the back batts that means i will use both fuses on the 2 runs of positive im running.
2 sundown saz 3000d
the choice is your buy more fuses/holders, or take the risk of burning your car down.
Scientia est Vox
damn man thats shitty i mean what are the chances of my wires actually grounding im not running them through or close to anything i really dont wanna buy 2 more fuses and holders that like another 100 i dont have at the moment.
2 sundown saz 3000d
Did you not see the guys truck that it happened to a few days ago?????!?!?!? :blink:
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
hell yea that sucked but he put his under the seat i mean i know what you guys mean but after dropping 5+ on a system im kinda left dry and still havent bought the wood yet. could i get away with it for a while then later on fuse them? and wouldnt running 4 fuses kinda limit the amount of power coming through those wires?
2 sundown saz 3000d
  • Who's Online   0 Members, 0 Anonymous, 993 Guests (See full list)
