Rebuildin' 2003 Grand Am
i like the stained wood, i would much rather be able to see the grain than have it blend in carpeted :D
Who ever said nothing is impossible never tried to slam a revolving door.
I too like the idea of using a hardwood to accent the amp. Too bad there wasn't a way to get those bolts to blend in some way where you used them to mount to the seat. It still looks good, but it would look better if they didn't stick out. Good work, keep up the progress.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
i actually wanted the bolts to stick out like that
i thought it would look tuff and kinda utilitarian...
i thought about going stealth but it will look good either way
makes me want to use allthread instead of the wooden dowels so the box and amp mounts match
im kinda ticked because i use vinyl decals to do the lettering i want but dj told me to get in contct with jagged edge kustom vinyls and its been a week and i need 6 decals... not much work
i asked for a pdf file but no response yet
more pics to come
w00t.
Have you had a chance to runn the AQ2200D?
Looks nice.
nope... no subs to power yet... sure does look pretty in my car
and the AQ4X90 is 3" shorter in width so the two next to each other will look really nice
i got some tricks up my sleve... just kinda broke and without time to get alot done
nice job man but if you like it then i love it.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
building lucas's box... getting there
Posted Image
didnt feel like taking pictures of this box since mine will basically be the same just different sub placement
almost done... just need to sand the top level
i carried the box by the dowels on the inside... box is super strong so far
Posted Image
i dont think i need to for strength, ud be surprised how strong those dowels make it...
ill use resin to do the other 45s, but i dont think ill use mat on this box
i will on mine tho... seeing as how its an additional 1000w and an extra 20lbs on the baffle
there's no strength benefits from resin unless u put mat in it right?
