96saturnsl Posted September 1, 2008 Report Posted September 1, 2008 if u have any other speakers to hook to the amp try that see if the amp has output. u may have burned out the outputs on the amp.
DUBIE Posted September 1, 2008 Report Posted September 1, 2008 if u have any other speakers to hook to the amp try that see if the amp has output. u may have burned out the outputs on the amp.thats what i said..lol
Twigz Posted September 1, 2008 Author Report Posted September 1, 2008 if u have any other speakers to hook to the amp try that see if the amp has output. u may have burned out the outputs on the amp. I don't have any extra subs I sold them. I don't have my other amp either I sold that. Fuck, I really can't trouble shoot this shit like I used to have spares around. Fear The Quack! Shot at 2007-08-19
The Performer Posted September 1, 2008 Report Posted September 1, 2008 I'd first put an ohm meter on the subs to make sure they are still completing a circuit and the wires aren't burnt, and second to make sure the ohm load is correct on them. Then I would try a digital multimeter on the amp output to make sure it's still making an output. Then if all is good there I would move on to RCA's and the head unit side of things. Sucks to hear that man, hope things are well with your setup though. CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner
DUBIE Posted September 1, 2008 Report Posted September 1, 2008 I don't have any extra subs I sold them. I don't have my other amp either I sold that. Fuck, I really can't trouble shoot this shit like I used to have spares around. just try hooking it up to one of your stock speakers in your ride..disconnect the wires hooked up to that speaker and hook it up to your amp ill say the 6*9's....just dont turn up the volume too much.....turn it up a lil and see if any sound comes out of it..
Nightshade Posted September 1, 2008 Report Posted September 1, 2008 It's easier to check the subs with a multimeter or just pull them out of the box to see if one of the wires is burnt on one of them. If you have a multimeter just check the wires going into the amp and see if they read a 1 ohm load or not. If they don't read anything at all then I am for sure that one of the tinsel's is burnt or broken. Do you have the level 5 coils in you level 4's? 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Twigz Posted September 1, 2008 Author Report Posted September 1, 2008 just try hooking it up to one of your stock speakers in your ride..disconnect the wires hooked up to that speaker and hook it up to your amp ill say the 6*9's....just dont turn up the volume too much.....turn it up a lil and see if any sound comes out of it.. that sounds like a good idea i'll try that one out. Fear The Quack! Shot at 2007-08-19
Twigz Posted September 1, 2008 Author Report Posted September 1, 2008 It's easier to check the subs with a multimeter or just pull them out of the box to see if one of the wires is burnt on one of them. If you have a multimeter just check the wires going into the amp and see if they read a 1 ohm load or not. If they don't read anything at all then I am for sure that one of the tinsel's is burnt or broken. Do you have the level 5 coils in you level 4's? yup, I do. I'll try this one out as well. Fear The Quack! Shot at 2007-08-19
ruel1977 Posted September 1, 2008 Report Posted September 1, 2008 check the rca and remote... Team Bombilyaz Pilipinas "TEAM R.E." Authorized Dealer It's not the BRAND! It's the INSTALLER! Car audio is not for the noob! So its not for you Fatguy!
audiofanaticz Posted September 1, 2008 Report Posted September 1, 2008 check the rca and remote... If the remote was bad, the amp wouldnt turn on, and he says the amp turns on. As other said, find a speaker, connect it to the amp and see if their is sound output from the speaker. You dont need a sub, you can use some crap 3 inch mid or whatever you got laying around. If the speaker works, you know the problem lays some where between your speaker wire and your subs. Are you still running that 18 awg speaker wire? I tried to hook you up with lots of 8 gauge and all you had to do is pay shipping. The tiny speaker wire you where using before (that looked pubic hair sized) could of got hot from all the power and melted and shorted out. The dc level 4s, should take 3000wrms all day, there should be no reason for a blown sub, or ripped tinsil leads (unless you where clipping your subs with a high gain). If you have no sound from the test speaker you hooked up either, try grabbing a cd player or something else that has a rca output, and hook it up to your amp and play it, a home cd player would work fine, you just need to make sure to have a extension cord to plug it into, and to turn your car on so the amp goes on. And as said before, use a digital multimeter and put it on ohms and test your speaker impedance. You said you have dual 1 ohm coils, so Im guessing you got each coil either paralleled down to .5 ohms then series the 2 subs up to 1 ohm, or you have each sub series up too 2 ohms and paralleled down to 1 ohm. Your ohm load should be around 1 to 2.5 ohms final load depending on boxrise and any other impedance rise from tiny speaker wire.
