amp for my btl(s)
thegr8cody
has anyone heard of the mean green alternators,they say 300% more than stock,and there the only ones i can find for a durango
its because the other companys build to your needs i know EA and Iraggi build for near any vehicle you just have to contact them.
mean Grean is a great company also though, i had one in my 98 Eclipse GSX
U sure because that would basically be a HC2400 per amp? 5 maybe instead of 4 rear batteries but I was thinking that 4 would be enough. Hell, a extra 280 for another HC2400 wouldnt hurt though.
00114-1.jpgTEAM MechMan Alternators
true,basically how this is gonna go is im sellin my amp and radio to get my other btl 18,once its ordered i'm gonna start on my wall that away i got alot of time to get my wall right,then income tax comes my amps,i get them mounted and plan my runs of 1/0 wire,which should be here this weekend,then the waiting game for all the power to push it all,so i just have to deal with starin at a wall i cant listen too  :ranting2: then i gotta scrounge around and mug some people  :shiftyph34r: for the money for the batts
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
[glow=red,2,300]U sure because that would basically be a HC2400 per amp?[/glow] 5 maybe instead of 4 rear batteries but I was thinking that 4 would be enough. Hell, a extra 280 for another HC2400 wouldnt hurt though.
I know of some one that had two of the big memphis amps (4000rms @ 1ohm) and they needed two of the Kinetik 2400 batteries so they wouldn't see any voltage drops.
thats all they needed was 2,my boy has 2 pc2000 soundstreams, and all he has is a factory alt and a hc2000 and no dimming
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
its never really a good thing to run a stock alt with all this power, i burned 2 alts on my accord running my 2 kicker kx2500.1s and later my colossus.  I honestly would do about 3 batteries in back 3k RMS alloted to each batteryplus a decent starter battery
my local shop has 8 huge svr batteries powerin that 4kw. :D
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Yea but those Memphis amps are huge power hogs and Im talking about 4-T2Ks with 4-HC2400 in the rear 1 for each amp and the amp for the highs wouldnt really draw that much. So thats 4-250amp fuses off of the T2Ks + 1-60amp fuse from the T3002=1060 amps of fuses.........1-HC1400 under the hood (1500amp) + 4-HC2400 in the rear with the amps (4x2600amps)= 11,900amps max off the batteries. 11,900 worth of batteries running 1060amps of fuses. with 2-260amp Iraggi alts..... And u still say that wouldnt keep the volts up around 14v?
so how do i fude my wire,i kno 1/0 is 300 amp,since i'm doin 2 runs do i just do 2 300 watt fuses up front,and fuse in between batteries,im new at all this fusing,so i needalot of help to do it right
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
well I believe u will have a higher fuse rating of just 2-300amp fuses on ur amps if u are running a true 8k rms. What u do is calculate up all the fuses on ur amplifiers....EX: say u have 4 big sub amps that have 200amp fuses on them each + a amp for ur highs that has a 50amp fuse u would calculate 200x4 + 50=850amps of fuses on ur amplifiers. Now the closest u could get to 850amps would be 3 runs of 1/0 with 3-300amp fuses. So u would have 3-positive 1/0 and 3-negative 1/0 wires from ur front battery to the rear batteries. U would put the fuses between the front and rear. Then of course u would have 3+ and 3- wires between each battery in the rear but u dont fuse those because they are already fused from the front. The u put a external fuse that is equal to the fuse of the amp in the line on each amp. So then taht would be 4-200amp fuses between ur sub amps and rear battery and a 50amp fuse between ur small amp and rear batteries. Plus u need to have just as many runs between ur alternator and ur front battery but I dont think u fuse that battery though because that is basically ur battery that ur car runs off of.
  • Who's Online   0 Members, 0 Anonymous, 1861 Guests (See full list)
