McLovin Posted April 19, 2010 Report Posted April 19, 2010 Damn Bibby looking good. Makes me want to bag my ext cab now even more. Damn joo!!! Credo Quia Absurdum
n8ball2013 Posted April 19, 2010 Report Posted April 19, 2010 I was actually at a show in NC a few years back and there was a guy with a bagged frontier that would lay out harder than any truck Ive ever seen. He actually had a shitload of them in the bed. lol I mean like hundreds of them . That thing would hit the ground so hard you could feel it if you were within five feet of it. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
meade916 Posted April 19, 2010 Report Posted April 19, 2010 lookin good Bibby! All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
bibby>Chode Posted April 19, 2010 Author Report Posted April 19, 2010 Summery: We didnt get finished as it got late on us. We quit at 10pm and had been working since 8am only with breaks for lunch and dinner. We only have about 4 hours worth of work to do. The front is completely finished. Frame notched, bags mounted, air lines run, valves mounted, power and grounds for valves run. On the inside of the cab, the 12v remote turn on is ran to a killswitch, then to the switch-box. Also a 12v remote turn on is wired to a killswitch then enough wire to reach the compressor spooled up ready to run back there when we finish the rear. The rear has the kp 4 link completely mounted except the pan-hard bar, the notches are finished except for being prettied. All that's left in the rear is the bridge w/ upper bag mounts, and the lower brag mounts. Then mount those bags, cut the bed, put the bed on, tank compressor in the bed and run the rear lines, valves and power lines. We still like another day before it will be wrapped up. Dad is coming back in two weeks to finish welding the bridge. (May 2nd & 3rd) Here are the pics... Me mounting the kill-switches in the panel from the dash. Cutting the top cups down to 2 & 1/2" Close up of the front notching. (for bag and tie rod) Still working on the kill-switches. (dad in the background) Dad's brand new torch, just for this project. Grinding the front cups smooth after cutting them
bibby>Chode Posted April 19, 2010 Author Report Posted April 19, 2010 This was right before i put the pass front bag in. Front bag installed Rear notches finished and ready to cut out the frame
bibby>Chode Posted April 19, 2010 Author Report Posted April 19, 2010 Cut that shit up!! Putting the bottom of the notches in. Notches all finished I lowered the jack-stands down to their lowest setting so the truck is currently sitting lower than stock. If the jack-stands weren't under it, the rear would lay completely out, and the front about 4" from the ground.
bibby>Chode Posted April 19, 2010 Author Report Posted April 19, 2010 Now this is the front being completely done. Here is a rundown of everything all wired up. Passenger side valves location airline from the bag to valve follow the red/black wires to the switchbox. (the two black wires you can barely see hanging down are the drivers and pass grounds. They aren't mounted yet since the battery isn't completely in.) Still following the lines, and the drivers side valve locations. (They may be moved once i'm actually finished.) Line from bag to valves Around the corner and into the cab and into the switch-box These two wires are power to the switch-box, and remote turn on for the compressor. but first they go to kill-swithes. (compressor so i can turn it off if it kicks on in a drivethru or something, switchbox so if it falls on the floor at 70mph and hits a switch it wont throw me off the road) Both pass and drivers air lines follow this patch to the rear where the tank will be One more shot of the finished rear.
JMZNeal Posted April 19, 2010 Report Posted April 19, 2010 you need lowered arms for the front and drop spindles to lay the 4" to the ground. JVC AVX-44 and 360.2 Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2 Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
bibby>Chode Posted April 19, 2010 Author Report Posted April 19, 2010 Yea, i know i need 2" spindles. I'll be real close then. I'm not sure what to do about the other 2". You say different lower control arms? Got any links? I'm thinking real hard about going and taking the jack stands out from underneath it. I want to see it on the ground sooo bad. Even though i cant air it up and drive it yet.
JMZNeal Posted April 19, 2010 Report Posted April 19, 2010 try suicide doors or air ride tech or airbagit.com. best bet is suicidedoors.com since you use them already http://www.suicidedoors.com/catalog/control-arms JVC AVX-44 and 360.2 Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2 Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
