ya thats what i thouhgt... the main thing messing me up is the fact i want/need to have active control of the midbass. How easy is it to control both 360 units?
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
i was wondering y you were takein out tha audiocontrol equipment but now i know y that controller looks killer  :^ but what i want to know is do you hear a diff with it or is about the same
very easy once you are familiar with how to operate the first one....i had about a month of "practice" before i aquired my second one so it was an easy transition.
Follow my Tweet (Twitter)
Guest MegaloManiac
Whats kinda crossover do you own? Can it do a 3 way active  (frontstage: highs,mids,midbass)
3way active can be achived.... use seperate amps per range and utalize their crossovers or use an individual channel of the 360 per range (but for the most eq control you would want to get 2 and utalize both of the fronts and 1 rear leaving you with the 2 channels of center 2 channels of rear and 2 sub channels)
  • 4 months later...
This may be even out of my scope but I shall venture in real quick:
Steve: Do you have to set both 360's seperately and "synch" em up band by band or will the one PDA do both at the same time?
If you can control both 360's at the same time via one pda that'd be teh sexy.
Also, will the RTA give you help on positioning the mids b4 you mount em? or will it just allow you to fine tune them based on on "attenuation", and even then only from wherever you put speakers versus wherever you put the mic?
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
i was reading on the rockford fosgate website about movein the remote jumper setting, i was just wondering if you use two 360.2 do you have too do it to both of them? and the same thing with MODIFYING THE UNITS. its say that you have to take out R13 resistor when you are useing two. but do you have to take in out of both 360.2?
you only have to do those mods if you plan on using either the master volume knob or master bass volume and want both to work on the same module......I dont do either. I basicly have the bass section of my system ran off one 360.2 and i use the master knob for that. No need for a volume knob to be on the second one, especially since its only running tweeters right now.
yup....actually i think its the other way around but same end result...
i think it was 2male to one female and split AT the 360.2's instead of at the deck.
The processors just need a base signal, then you use the palm pilot to make sure every amp gets the proper signal from the 3sixty.
its actually pretty easy, i say forget all that modding shit......unless you use the master volume for both which i dont. I only use the master-bass volume and the bass only comes from the one so no problem there.
