anybody experience this problem b4?  a buddies hu turns off by itself when playing at high volume.  then turns itself back on after a few seconds.  we swapped out cd players and still does the same thing.  where should we look next????? :help:
the wiring appears to be correct. we even put a new 1858 harness in it just in case it was that. all harness wires are soldered and heat-shrinked. with no bare wires.  thanks for the input though!
in most head units if you drop volts below 11.5 it will shut off.  even if you read 14.4 if you have a below standard ground to the head (which most factory wiring is below standard) it will drop volts at high strain times.
Its all about the Install !!!!
http://www.youtube.com/user/audioaddiction863
Bass Race Florida State Champ runner up 139.9 2008
Bass Boxing Florida State Champ runner up Middleweight 2008
i had the same problem, with a JVC cd player, used to cut off at high volume,
Redone the wiring and didnt do it since for over 2 months :D then i changed hu. pioneer!
Upgrade your BIG 3 wiring. I had the exact same problem. Deck would turn off at high volumes of bass. IPOD, cd player or radio, did not matter,it would turn off and then back on. After I did my big three and the problem went away.
Try it
Official Scores at the Dash. and YES. My Bass Boxing is louder than Burp! - 155.5 DB Drag Burp- 155.6 - IASCA Bass Boxing on music (30 seconds straight) sealed up Builds 1. The Acura Integra build = http://www.stevemead...s/page__st__6802. BLK SIN Build = http://www.stevemead...w-pics-10-6-07/
i had this problem as well...i had a loose ground wire inside of the harness...so i yanked it and wired it straight to the firewall. it could be low voltage also as previously stated.
i likes me some audio stuff...
Only one way to be sure pull out the volt meter
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
  • Who's Online   0 Members, 0 Anonymous, 1071 Guests (See full list)
