thats what rf did with mine replaced the whole board supposedly. I never opened them to check but thats what they told me. Even when i moved the smoker it would still do it. Had no idea why just that one was a lemon.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Are you sure its not a whole new pc board?
I know tons of people that fried kicker amps, and like i said they just take the old board out and put a new one in it. less time consuming, and cheaper.
If it happened 3 times, i dont think its the amp.
Its maybe how it is setup, if your blowing capacitors (i think c17-1mf is a capacitor), there maybe a problem with your amps power supply.
otherwise you might have some bunk RCA cords ran in your car, maybe they are messing up somehow.
What about your sub coils? Do they read fine and rest at one ohm, and not jump around when you read them on a dmm. If your coils dont hold a constant number your sub could be frying the amp. I just had that happen recently.
Id really try some new rca cords since they are cheap and not hard to replace. Maybe find a better ground or make sure you have the best conductivity possible.
Listen to this guy! ^^^ Seems like a damn expert!! :good:
Derp.
sig worthy!
Lol
I just took lots of amps apart, and made simple repairs on many amps in the past.
Sometimes I learn the hard way (which seems to be the way to make you broke) but theres just small things that you may never think off.
sig worthy!
Lol
My first sig worthy reply! :give_rose::yahoo: :yahoo: :8)
It just takes lots of time and patience to repair your own amps doesn't it? (And skill)
Derp.
not sure it's a whole new pc board, the only thing i have documented from kicker on me is that they replace the c17-1mf, which is the capacitor, you're right) it could be the amp though... like i said that's all they've replaced, and my amp went out a third time, so i'm not sure what the problem is this time. that's why i want a different amp and if the same thing goes wrong, then i'll know it's something i'm doing
on the rca's, i'm running the kicker rca's, kinda expensive but they're nice, and i hooked my rca's into another car right next to mine, and still nothing
as far as checking the ohm load on the sub, haven't done that, but i ran it on my buddies zx750 for a couple of days and no problems with anything...
i'm out of ideas on what it could be, that's why i want to exchange for a different zx1500
another thing, i've put my sub into the box twice, first time drilled pilot holes, screws went in good, second time it seemed that probably 6/8 of the screws went in crooked... i'm afraid to pull the sub out then drill it in and have the wood fall apart on me and have them not grip... i'm using 3/4" mdf and know it splits sometimes... any ideas on how to fix this??? i have more slabs of mdf but don't want my sub up on a pyramid haaha
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
Double baffle!!!! Drill new holes
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
haha and what am i gonna tune this beast to??? haha
but if i drill new holes, that three different screw spots, in the same spot haha, it'll all be broken uppp
Alpine CDA-9883
Kicker ZX350.4
Is your charging system up to par?
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
Take this as you will. Ive had multiple problems once I put power to my subs.
First problem was my custom rca's that I had custom made by magalowmanic. The solder job on them was crap and the center pin wire was grounding out, causing my amp to protect. Resoldered rca ends and problem solved, but then got a hook up on some old school Stinger King series rca cords. Triple shielded, really nice cables.
Then after a week of bumping I had a coil on my subs unwind. Everytime the sub hit I heard a ting type sound. When I checked my voice coils on a dmm (digital multimeter the coils where reading from 0.9 to 2.6 (each coil should read a constant 1.4 ohms) This started to kick my amp into protect again. So with that being said DD will have my speaker today/friday for a recone. Sometimes just a rubbing coil maybe enough to fry a amp. I think you said your coils are dual 4 ohms. So if you got one coil jumping around on the ohms when you check it on a dmm, this could be your problem.
You said you bought the amp from an autorized dealer which is good because you got that warranty but paying shipping back and forth does blow goats. Im affraid that kicker may get fed up with seeing the amp so many times and may charge you. Maybe they just replaced the capacitor, but I dont know for sure.
Dont know if you ever had the cover off to read the serial number on the pc board but if that number changes that means they are giving you a new board in the same heatsink.
This is one way to fix the problem. The other way is get 8 t- nuts and bold your speakers in. just make sure to get a bolt size that will fit thru your holes on the basket (around a 1/4 inch bolt by 1.5 inches long). The t nuts go on the inside of the box, and have metal prongs like teeth which grab into the wood. Then you can take your sub in/out as many times as needed without weakening the wood. Of coarse you will have to predrill the wood to the bolt size.
I run these on my wall for my subs and port.
Drilling new holes is a waste of time. You have a square speaker so you cant really turn it just a little bit and screw into fresh wood. The square subs have more cone area as a normal round sub, but if you take them out enough you run into the problem of screwing into the same holes over and over.
  • Who's Online   0 Members, 0 Anonymous, 1055 Guests (See full list)
