ok might be a dumb question but i have a factory amp that i had to hook up to the REM wire from the harness or they would play off of the deck alone.... then i a have my rockford t1000's remote wire hooked up to the same remote lead is this dangerous? if so how would i run another Remote wire
sorry if this is in the wrong section
thanks
1 Fi Sp4 18
Crescendo 2k
selenium mids
audioque supertweets
Hifonics for mids and and highs
1/0 power and grounds
---> on the way singer alt and possibly another
2k depending how sub likes 1 2k
I assume you are running an aftermarket H/U since you have a remote wire in the harness. The ideal situation would be to install a relay on the remote wire and than each amp will have its own turn on. Not sure if the way you have it set up is dangerous or anything but better safe than sorry. It would suck to burn up 2 amps.
2 amps should be fine any more than that and iu would put the relay in.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you wouldnt burn up the amps, only the remote wire. if the amps dont have enough juice in the remote wire, they just wont turn on
okay what type of relay do you recommend?
1 Fi Sp4 18
Crescendo 2k
selenium mids
87 constant power. 85 ground 86 head unit and 30 to the amp. remember run the positive and negative to battery, reason for this so there is no questions that it is working.
edit just looked at mine.
Edited by B slaps yo mama
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
this might help a lil bit, u can get this , http://www.partsexpress.com/pe/showdetl.cf...tnumber=330-070 and this also http://www.partsexpress.com/pe/showdetl.cf...tnumber=330-075 , should be all u will need, but what i normally do is just wire off the red acc wire and fuse it off the headunits harness for a remote wire but the relay should work better tho, hope this helps man
Edited by tacomabanga1986
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
I believe that 85 would be switched+12volts, 86 would be ground, 30 is also +12 volts, and 87 is to the amps.
Edited by Nightshade
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
i believe im fine right now with the factory amp and my sub amp since the factory one is just powering my highs ive been bumping for like 4 months now and no problems this is for further reference if i get a 4 channel for my highs when get 4 more tweets
1 Fi Sp4 18
Crescendo 2k
selenium mids
close
why would you get the second part? the female? pointless. just run a female terminal off of the relay.
close too
no offense, but it doesnt matter what you run off of an amp. its still turning on.
http://www.the12volt.com/relays/page5.asp#top
go to the fifth section down. just a standard single pole double throw (spdt) relay that you can buy at ANY parts store instead of ordering it from online and waiting for it to come in.......
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
